Atl-atl is at it again, Ive added another truck to the fleet. 2024 Power Wagon inside!
TommyG
Ahh. Yes its going to require trimming and bump stops and I will be replacing the entire suspension. But it could be done without aftermarket suspension if you really wanted to.
The sawzall / cutoff wheel / plasma cutter is your friend for sure.
mog
Kodiak Buckaroo
Oh yeah, Ive got a plan that is starting to come together after test fitting that Toyo. Unfortunately I under estimated how tall a brand new 40 with full tread is. There will definitely be cutting...
Awesome wheels/tires 😍 Looking forward to your progress
A lot of cutting goes on when install the front & rear AEV HighMark fenders, so perhaps their instructions will give you some 'ideas' as where and how much to cut.
I recommend running the Dodge Off Road Steering Brace with 40s.
Atl-atl
I have gone through the AEV installation guides looking for tips. I dont plan on pushing my front axle as far forward as AEV does unless push really comes to shove. What I need is to find bulk fender liner material so I can build my own liners after Im finished trimming.
As for steering Ill be running hydro assist. I have not spoken to anybody (DOR or otherwise) about if that takes stress off the steering gear (does this negating the need for a brace?) but Im not opposed to the brace so long as it works with the PSC gear I have coming. Small price to pay to protect expensive new parts.
TommyG
I have not messed with this material so I don't know how it would handle engine heat. Might be worth a phone call or email:
One of my buddies was into rally and I watched him make his own mudflaps out of all kinds of stuff. I have also seen liner fenders made from cut up tractor trailer mudflaps. They seem to work well also.
Atl-atl
Its about to start getting good in here. The last of the suspension bits have finally rolled in and Blazer camper #2 is on hold for a couple weeks so that means time to tear into this thing. The full list, for now, is the following:
  • Thuren Power Wagon front coils
  • Thuren Power Wagon rear dual rate coils w extended sway bar links
  • Thuren rear coil adjustable shim kit
  • Thuren front track bar with bracket
  • Thuren rear track bar complete kit
  • Thuren weld on front lower shock mount reinforcements
  • Thuren spec Fox 2.5 DSC shocks
  • Carli front sway bar relocation brackets(if necessary)
  • Carli weld in front coil isolator supports
  • Factory non Power Wagon coil spring isolators
  • PSC steering gear for hydro assist
  • PSC hydro assist Ram
  • AEV hydro assist kit for Ram HD trucks
  • Synergy radius arm brackets
  • Synergy 2" front bump stop drops
mog
Kodiak Buckaroo
Awesome! No Thuren rear boogie bumpers or Thurn rear swaybar? I know a guy (me) who had to take his off when he put his camper on (replaced with airbags and Hellwig swaybar), who I bet would part with them ;)
Pretty much the same set-up I have, except with 2.0 Fox shock (planning to upgrade to the same as you), Carli HD balljoints, and no PSC hydro steering. I have not had an issue without the hydro steering, but I sure would like to drive one with it installed to feel the difference. I'm always looking to upgrade.
I am looking forward to it all coming together.
BTW-great photo layout
bdpkauai
