Atl-atl's Dodge Ram 2500 Regular Cab Long Bed "documentation" thread.
Atl-atl
Well its 95+ degrees with triple digit heat index so I decided to outfit the garage for inside work. Its 2/3 underground so it stays really cool which is quite nice. And because I cant leave well enough alone I decided to start ripping apart the campers interior for a little update! Its going to get similar treatment to my last camper but without ripping the walls out and replacing the insulation and all new cabinetry. This is more of a 'refresh' than a remodel, although I did make a stop at a granite counter top place...
It fits inside on its cart with the top up!
Before pictures
Atl-atl
So I removed all the window coverings, removed the lower bed supports because they will not get re-used, removed the floor mount for the table and got the stain done. It did not take quite as well as I hoped, probably because 1. its ridiculously humid right now and 2. the wood had already been stained. Either way its ok but its going to take a very long time to dry and now its really busy inside the camper because I introduced two new shades of stained wood. I will be tackling that issue this weekend with new wall covering, Im quite excited to get rid of some of the fake wood paneling. Thermostat, fire extinguisher, Heater cover, Propane sensor and CO sensor have been reinstalled. I also got the floor laid and it looks WAY better than the linoleum. I just need to cut some 1/4 round and stain it for trim and then figure out where to put the table mount on the floor since its not going back where it came from due to poor fitment previously. Also depending on how the fiancé feels after taking pharmacy boards tomorrow we might start to tackle the upholstery this weekend. Its already looking much better and more modern. LOTS more to come soon! :victory:
Atl-atl
Swung by a commercial upholstery place today looking for cool plaid fabric. I was told that plaid is not currently on trend and they don't have much so I grabbed a sample of this awesome brown and cream tartan and politely told the lady Ill be bringing plaid back in style! She laughed, a lot. :sombrero: The small check pattern fabric is my wall covering, its actually the same stuff I used in my last camper and it turned out really well. I got an entire bolt of it for free on a TI job I did a few years ago, its really expensive stuff that was rejected by a typically snobby interior designer due to "quality control issues" with the fabric. Ill be using it on the upper walls. The plaid will be for the cushions and the mattress.
Atl-atl
More updates! It finally cooled off to 85 degrees and 60% humidity so I could actually work outside today. Got almost all of the wall covering done: front wall, passenger side and back wall. Also, mineral spirits is great at shining up aluminum! Im really happy with the way its looking now. Hopefully I can get most of the upholstery done this week, although the old stuff is growing on me. Items left on my short list are upholstery, rear door update(I'd love to have a screen door if anyone knows how I can make that happen), ice box surround update, new countertop and backsplash.
Regcabguy
Oil eater.
Nice job especially the flooring. I need to do my Northstar with something like that.
Mine came with metro gleaming white linoleum.
Atl-atl
Thanks, yeah the linoleum had to go. $16 for one box of laminate flooring is all it took, well worth it!
Atl-atl
Speaking of the cost of things. The plaid fabric I want is $14.99 a yard. Using this sweet fabric yardage calculator Fabric-calculator.com I figured out I need just over $200 worth of fabric to reupholster my cushions and mattress. Eek, thats a little more than I thought it would be.
Atl-atl
Went to the U.P. for some MTB'ing. Stayed at a friends house in Ishpeming but would have rather been in the camper! The hills are huge around here, technically they are mountains. The tallest one being nearly 2000ft. I cant wait to get back with the camper and do some mini overlanding/adventuring. There are gravel/fire/logging roads everywhere with all levels of difficulty.
Washington St in Marquette with Lake Superior in the back ground. Its really like an ocean, so cool.
Cliff jumping
Came around a bend on a MTB trail and this was the view. Through the trees to a golf course and Lake Superior in the back ground. The U.P. is absolutely incredible.
Active and retired mines everywhere in these parts.
Midwest sunsets
Atl-atl
Well after two days of completely busting ******** we have almost completely finished the upholstery. Only thing left is window coverings which are under way currently! Hopefully they'll be done this evening but we need a break after two full days of working. There are two small cushions, two large cushions, one flat board with fabric and the mattress.
The four cushions were simply foam with upholstery stretched over and stapled to a plywood backing. Instead of taking them completely apart I decided to simply cut stretch and staple the new upholstery over the top of the old stuff. I wound up using staples that were too short(1/4") yesterday and started over today with 3/8" which worked much better. The only place they didn't work were the thick corners. Even though this fabric doesn't look very soft or thick, it is. Its commercial upholstery grade and is really nice. I wound up having to use #16 upholstery/carpet tacks in the corners but it turned out nicely. The mattress had a zipper and a vinyl backing/sides. We decided to reuse the vinyl because its clean and in great shape. This made sewing the new mattress cheaper and much easier/less time consuming. Im blessed with a mom thats a seamstress so she cranked through the mattress like it was no big deal. While I slaved away on the cushions. I think I have carpal tunnel, should have gotten that air stapler I was looking at.
Finished cushion
Plywood backing before stapling on the extra wall covering to make it look nice.
Here is what the bottom corner looks like with staples, tack and bottom cover. I used the same material from the walls. I had a bunch of extra so I cut it to fit, rolled the edge and stapled/tacked it in place. This came on the suggestion of mom because she was worried the raw plywood backboard would ruin the new fabric. Mom is always right!
You know you're super pro when the pattern lines up across all of the cushions, including the mattress! :drool:
Im beginning to think the color palette in my head is going to be just as good in reality!
Atl-atl
This job is looking sweet. Keep up the great work.
Thanks! And I am!
My plan today was to get all sorts of misc. stuff done. Unfortunately it turned into running around all day so I could rebuild the rear door that practically collapsed when I tried to re-cover the inside. Also my tire with a slow leak that used to take a few weeks to get low now is losing all its air in two days time and since they don't make these tires anymore I have to figure out what to do. Do I go down to 35s? Do I stay with 37s? Do I go up to 40s??? I really need to re-gear if I do that but I also need to do balljoints so...this is getting out of hand.
So I rebuilt the rear door! What started as trying to take the sides off so I could glue on my wall covering turned into rotten wood, glass falling out and the lockset falling apart. YAY! More things to buy and more ******** to do! #headbang This required a trip to the depot for a new lockset, wood and seal for the window. Of course my home depot doesn't have butyl tape so I had to go to 20 minutes away to camping world.
The door looked almost identical to my last one. The bottom piece of wood had completely rotted away.
It was pretty rough, this was the inside!!!
I bought a 2x2 stick of cedar to replace the missing and rotten wood. It worked almost perfectly until I found out it was about 1/4" wider than whatever was in there. It took quite a lot of massaging the lower aluminum trim piece to get it back on. Oh well.
Looks way better but some of the dents are still visible through the new cover. The textured metal piece was glued to the foam so there was no way to flatten it back out. Oh well.
Regcabguy
Oil eater.
You're welcome! Everything from Colorado to the East is very green this year. Sorry about California!
I love living here but summer is tourist season and we get bombarded.
I hope to get up to the four corners region and visit Mesa Verde and some of the Anasazi ruins.
jacob_lashell
