Auxiliary Lighting
Love the light set up. Love the wind fairing even more, is that factory to the Voyager set up?
Low profile voyager rack with the fiberglass fairing from voyager, yes... I attached the fairing using some hose/pipe brackets and some big washers/bolts. The LED bar I used mounted to the two light mount tabs with some right angle brackets. Its a tight fit, but it is solid. In the pictures, you see wooden blocks glued to the inside of the fairing with stainless steel zip ties, but i removed those later, replaced in the middle and with with the brackets/bolts.
For the back, i used some KC 1" light mounts on the rear bar. They adjust pretty well. I used some larger washers and wing nuts which lets me adjust up/down and side to side pretty easily.
mbobhat
