Back to a truck Camper!
Freebird
On my Alaskan the 2x2s are space about a foot and a half (or so) apart by the factory.
I have to believe that distance is based on Alaskan camper construction, tho, which is pretty strong.
(All the cabinets in the base are structural to the base integrety (2 part camper-upper roof, lower base), each cabnet reinforcing the wall/floor junction)
YMMV?
docdave
Aspiring overlander
Haven't posted for a while.... traded trucks again. Found a 2011 crew cab hemi, auto that I just couldn't pass up... I like the styling of the 2004 better, but, more horsepower, auto tranny, bigger cab, better ride, and only 34000 miles. SO..... need different tiedowns.
Went for something that attached to the frame on both sides, mounting plates screwed to the sides of the frame with self tapping screws. 2" square tubing 1/4" wall. The end pieces are 1 1/2" tubing pinned like a receiver hitch.
Used vinyl coated cable instead of chains, thought they look neater. The end pieces are removable so the unit is nearly invisible when the camper is off.
Used Happijac rear mounts, just couldn't come up with anything that was as handy.
