VanIsle_Greg
Not yet...lol, but I will be!
Just a heads up Australian 4WD Action Magazine did an article thoroughly reviewing over 50 different portable air compressors in the issue number 169 on news stands today. Just grabbed it from B&N now.
I've got my mv-50 hooked up on a 2.5 gal tank with a pressure switch, it works great, but had to get some serious high temp hose to go from the compressor to the tank as cheap stuff failed under the heat. I really should rebuild it with some metal tubing to dissipate heat.
Full article online here: http://www.4wdaction.com.au/sites/default/files/4WD169 036-054 FEATURE air_2.pdf
Note: online article says print article has errors, more: http://www.4wdaction.com.au/articles/2011/issue-169-air-compressor-comparo-corrections
You guys praise the MV-50 and I have been researching them and it appears that others are not satisfied with the unit and the common theme seems to be the fuse housing melting. What is weird is the older reviews are good, but the newer dated ones show problems, did they change the compressor or manf. perhaps? Amazon reviews didn't seem very positive. I'm in the market for an air compressor and was excited after reading this thread but now have a nervous trigger finger on buying one. Any info?
Thanks, J
