Camp Stove Help!
About the video comments about the hose getting stiff brittle and holes in it. Best practice when using a hose is to turn off the propane tank valve first and let the device burn till it goes out. Reason for this, is that there are oils in propane. These oils leach out and do attack the petroleum based materials the hose is made of. When you shut off the device first then the tank you trap propane in the hose. For best hose life drain the propane from the hose.
M meadow build
