Espar Airtronic B4 (Petrol) 12V Heater
New in the box, never installed, complete setup
Manufacture date: 7/30/2018
This set up includes the following:
I got this to use for a camper build that never happened. Hopefully, it can happen for you! The only thing it does not include and you may not need it, is a mounting plate which vary in price from 30-70 dollars depending on what you need)
This is a 4KW heater equivalent to what is now called the airtronic M2B4 and with the altitude kit, it is good up to 9,000 feet or so.
Shipping will be from 99516 and the box dimensions are 17x17x9.5 and it weighs 23 pounds. This is a very heavy duty box and everything is well packed in original bags/boxes.
$1800 (not including shipping)
PM me with questions. Thanks for looking.
- Heater and fuel pump
- Exhaust with muffler and intake tubing with all hardware (clamps, end caps etc)
- Stainless steel through wall exhaust outlet
- Air duct with end cap/nozzle (this is compressed in the picture)
- Fuel lines (from tank to pump and pump to heater)
- Fuel tank pickup
- Easy start TIMER with harness ( this is not the Easy Start controller, This is the timer unit which provides the on/off and thermostat functions along with a 24 hr timer allowing you set a start time.
- Wiring harness with fuze block and all connectors/fasteners
- Altitude Kit with harness and connectors (adjusts for high altitude use to optimize burning and minimize carbon buildup)
- Complete manuals (paper and CD) for heater system, altitude kit, controller
- BONUS ITEM: Remote control unit with two key fobs (this is a used item I installed to operate an Espar B5 Hydronic heater in another van and removed when I sold it. This should work with this heater as well)
