"Floating" Self-Leveling Bed Frame Ideas?
what about a metal frame the same dimensions as your mattress and four tube legs on each corner that each slide into a larger tube leg with holes drilled at different increments allowing you to raise one end of the bed or the other or even go side to side if you wanted to.... just trying to think simple here.... something like the legs on an easy up awning
Good thought but a mattress and frame is very heavy, so it might be difficult to lift up a corner in such a tight space. Leverage is his friend
Kevin
ELShockley
