Hi Lehel..........,
To the original poster, .....I got what I considerred to be a very accurate fuel reading on a brand new FG84 about 12 months back. Had to deliver it about 2000kms away in central Australia and basically sat on the speed limiter the whole way. It was bus and limited to exactly 98 kph. Bigger wheels so the rpm was lower too remember. Here's a pic.
You can see that apart from the bullbar it is quite "aero" and the Wind Deflecter (W.D) fitted to the cab roof definitely does help because I noticed if a road train went past in the opposite direction there was virtually no buffetting at all. The vehicle weighed roughly 4600kg (tare) with only 20 litres of fuel onboard, max height was 3.3 metres to the top of the air/con pod and wheelbase was out to 3900mm. Absolutely standard engine and exhaust but there is a little bit of a ram on the air intake ( see poking up from the roofline in the pic). Fitted with 285 / 70 R / 19.5 tyres and over the 2000kms, averaged 20 litres/100km or 5 kms/litre or 14.1 miles/gal (Imp) or 11.8 miles/gal (US). Certainly nothing to brag about but remember that it was a big vehicle overall. Notably it was brand new too having a tight engine with basically zero kms on the clock at the start of the trip. I've heard of these trucks still improving fuel consumption up to 100,000kms but I would guess this would average out to only another 1 km/litre (2.4 miles per US gal) ......1.5 tops.
Carbon60 and others in North America, our FG 84 model is slightly diffrerent and although has the a 4.9 litre, multi-valve, common rail, turbo/ intercooled engine with EGR , there is no DPF. Incidently, have been promised a drive in the new 2012 3 litre model which does have a DPF this coming Friday if anyone's wants to ask questions.I am willing to guess the new engines will be a vast improvement on fuel consumption but we'll wait and see by how much...not because of the DPF but the power curves for such a small engine are staggering. Efficiency must be way up.
The earlier model FG 649 was considerably better on fuel. These had the old 3.9 litre engine but were also less powerfurful. .........and to throw weight to the "aero" vs weight issue, one of the best fuel consumption figures I've heard was from a FG649 driver (and trusted friend) who averages 7.5kms/litre and once recorded 8kms/litre in "expedition" trim which although not condoned is often up around 7ton GVM. Tsk, tsk , tsk. I mean 2 x trailbikes, RIB and outboard motor, enough battery power to run my house, and enough water and supplies to last him 3 or 4 months in the desert, big genset, air-con, espresso machine, etc, etc. etc, etc............now despite all the gear carried it is probably one of the cleanest FG's ever built in terms of aerodynamics and I would therefore say that must weigh heavily on the performance figures.......he finds himself cruising slightly under 100kph though on the highway......more like 90 or 95kph. Exhaust was standard other than a shorter tailpipe and no chip......also runs very tall 930mm diameter tyres. He has since fitted LPG and tells me that fuel consumption has improved even further. (Note: They tell me LPG makes a bigger difference on less efficient engines without common rail injection).
