Full Size Dodge Thread
Great looking truck!
Curious on the braking difference between the second and third gen front brakes?
I am on my third dodge Cummins-my current one is your trucks twin, But without the tasteful upgrades yet. Although I did have the metal-cloak control arms on my 07 and thought they were a great product.
I'm wanting to do much better suspension on my current 01, but I'm torn in the suspension department-so any input from you would be much appreciated! If you'll bear with me-I have a few questions: How do you like the 5160 shocks? Where would you recommend getting them? How much better is the ride? If you had to do it over again-would you have gone with Fox or Kings instead?
I had the 5160's on my 2006 for about a year and then upgraded to Thuren Kings(3 years ago). The 5160s were a lot better than stock but compared to the kings you get what ya pay for. 1/2 mile of washboard the stocks would be faded and useless, maybe 2 -3 miles on the 5160s but the Kings almost never fade even after 15 miles of blasting down constant washboard hauling a heavy camper.
Just my experience.
Chris
Chris, what about ride quality on the road? How do the Kings compare to the 5160s?
I have my Kings valved for carrying a heavy camper, so when the truck is loaded it's smooth. But unloaded is abit rough. It's all compromises.
The 5160s were abit softer so the camper swayed more, but unloaded the 5160 are softer than my Kings. The beauty of Kings or any of the higher end shocks is the custom tuning.
Chris
Really appreciate the responses fellas! My dream is Thuren springs AND King's, DOR shackle flip/block removal, and track bar with 08+ steering linkage topped off with MetalCloak ca's.
Better start selling things/saving!
TommyR-let me know about those brakes after you get then dialed in would you?
I get to join the dodge group. just picked this up last week. 2003 ram 1500 hemi 4x4 quad cab. 168k on the clock. its going to mostly be my work truck for my lawn service but it will also serve haulin kids around and some offroad fun.
first thing i want to do it is get some of the chrome off.
2005 Dodge 2500HD 4x4 Quad Cab
5.7 Hemi, Auto trans, AFE Stage II CAI, Superchip Tuner
Lockers and 4.56 Gears
5" lift springs on front, 3" Blocks and Air Bags w/ 3" spacers on rear
37/12.5R17 BFG At's on 17x8.5 ProComp 5129 wheels
Bushwacker Extend-A-Flares, Westin Sportsman one piece grille guard
Kargo Master Canopy rack, Front receiver hitch
11,000 lbs Portable Winch
Led lighting (360 degrees) 1- 50", 2- 36" and 4- 6.5"
Big Steel - Sport Canopy, DAC truck tent
CB radio, UHF 2-way radio, Garmin Rhino GPS / GMRS handheld radio and 3w Cell booster
205L (55gal) Aux Fuel Tank
Bed in canopy w/ storage drawer
I know this was posted 5 years ago but DAMN that is a great looking Ram!! Makes me want to get one.
This is my 22 YO daughters "Weekend" 1st Gen 1993 Dodge W250 5.9 Cummins 4WD.
For a daily driver she drives a 2001 Chevy 1500HD 6.0 Gas Crew Cab with 355,000 miles that is still running the original 6.0 LS Gas engine with 1 transmission rebuild. Pretty amazing truck!
My wife's "Weekend" truck is a 2008 Hemi 1500 Big Horn Crew Cab 4WD.
My daily driver is a 2001 Dodge 2500 Extended Cab Cummins 2WD.20180115_151829_resized.jpg20180115_151844_resized.jpg20180115_152026_resized.jpg20180115_152057_resized.jpg20160610_093849_resized_1.jpg20171128_100627_resized.jpg
2000 RAM 2500 Diesel with custom camper. Rear bumper mostly done, Front bumper started but not installed. I love this truck and will never part ways with it!
Photos from Courtright Reservoir, Imogene Trail, Sedona, and Sandstone Canyon
Here is my 2001.5 Dodge 2500 4WD short bed: A small hardside Lance Camper lives on the back now full time.
This is one of the reasons I bought the narrowest (86 inches), least tall (6 feet, 4 inches inside), and lightest (1842 pounds, wet) camper available at the time.
and a couple short vids in the Anza Borrego Desert: click to open;
https://www.dropbox.com/s/ns02z7g1q1jhu0r/up a rocky cyn Anza.m4v?dl=0
Watch this one to the end to see how steep it was:
https://www.dropbox.com/s/y9nfstvqf6hk4ab/up Fish Cr. Anza.m4v?dl=0
and might as well give you the specs on the modified truck: approaching none of it to the Cummins and most of it to the drivetrain. 174K miles. Bought it new in 2001.
In 2001 I bought a new 2001.5 (the ".5" is the addition of rear disc brakes) Dodge 2500 4x4 High Output Cummins Turbo Diesel, NV5600 NV241HD (wide chain to reduce the negative effects of shock loading when snow plowing), short bed (6-1/2 feet), 3 inch front coil spring spacer lift. Transmission ratios: 5.63/3.38/2.04/1.39/1.00/0.73/5.63R At 27% overdrive, this has the tallest top gear of any of the 6-speed manuals.
TGC Top Gun Customz 2000-2002 Dodge Ram Control arms for 2500/3500 4x4 for 6” of lift but for only 3” front coil spring spacers placing the front axle 1-1/2 inches forward.
4” exhaust system with resonator delete. No smog reducing add-ons, just a pipe and and throatier muffler
Vulcan Big line Pusher Pump Kit relocation to frame in front of fuel tank.
upgrade lift/transfer pump and fuel tank sending unit
Low fuel pressure alarm (idiot light goes on below 5 pounds pressure) I still run the original VP44 injector pump.
K&N Filtercharger PN 33-2056 /2006
short tube on turbo waste gate to engage turbo at a lower RPM
SpynTec Dodge Dana 60 Hub Conversion Kit, inner spindle bearing kit, new Dana 70 spindles, new Timken bearings, hub seals, Dana 70, 35 spline outer stub shafts, Mile Marker Dana 70 Lockout hub assy, factory ABS sensors and studs. Front axle disconnect (CAD) delete. Front unit bearing delete. Add front 35 spline Eaton Detroit True Trac torque biasing, gear driven limited slip, and 4.10:1 gears.
Dana 70 Mosier 35 spline front long and short front axle shafts. Stock 32 spline axles deleted.
Dana 80-35 spline rear axle with Eaton Detroit True Trac torque biasing, gear driven limited slip with 4.10:1 gears.
8 leaf rear springs: 3 upper secondaries, 1helper spring in stock spring pack. Stable Loads. Rancho 9K adjustable shocks. This translates to a 3" loaded lift with the loaded camper on.
GEN 4 tie rod, drag link, TRE’s, and pitman arm. steering stabilizer. Upgrade steering box and pump.
10” x 16” ‘Power Wagon’ Stockton steel super single rear wheels (1/2” plate center hubs) 4-1/2” B.S. Stupid high load rating.
7-1/2” x 16” steel front wheels. 6.25” B.S. unadjustable 4WP stiff shocks front. With a load or not, the front axle weight does not change appreciably.
35 inch Cooper AT3's in a 315/75 R16 size, load range E: 3860 pounds. Lots of sidewall for deflating on sand.
New factory clutch, T.O. bearing, pilot and rear main seal
Warn Transformer winch carrier, Warn #30092 transformer grill guard with added tubing and radiator saver. Fairlead #69604. Warn #62027 foot forward winch mount. Warn 15K pound winch. Camper jacks and rear seat removed for long distance travel.
12 ton hydraulic jack with jack board that will fit under the axle on the side with a flat. Lots of recovery equipment. On board air and ‘Safety Seal’ on wheel tire plug kit. Receiver hitch square tubes front and rear. Aluminum rack when needed. Fits front or rear.
Nice truck and camper. Looks similar to a Callen.
2eleven
