I think work like that is why I suggested you do your own paint-job!Still need to clean off some smudges, but I think it turned out pretty nice. ... What do you think? ...
Pretty cool idea. Ikea has some under bed slats like this. The Europeans seem to like the slat style on Range Rovers. It's not a roll up, but pictured below is a slat bed. I'm thinking an RV 4" memory foam mattress is what I want. They come in 48" x 75" size, which is difficult to find.The span strength will depend on the weight I think. We use 3/4” spanning 40” for two and there is a bit of sag but not bad. You might consider making a rollable/foldable pallet of narrow (3”) slats of a strong wood like teak. It could be arranged together with a similar width webbing and equal air space between each slat.
What is the mattress you plan to use?
... First option is (3) 48"x 25" x 3/4" AC plywood. I can take these planks down and get them out of the way, so I can walk around. It will also allow plenty of headroom when pop top is not up. Will these be strong enough to span a 4' gap without additional support? ...
1.5" square ash "slats", with webbing for quick setup and consistent placement, would be extremely strong, but one would want to make sure the webbing held them securely in place when in use.Pretty cool idea. Ikea has some under bed slats like this. The Europeans seem to like the slat style on Range Rovers. ...
Is this a sleeping platform for the JK in the background?We covered the main surface and all the rough edges of the ply with some thin fabric for speaker cabinets. Makes it a lot nicer.
With all your fiberglass skills I bet you could make some lighter and stronger pieces.
yes it is. It stays in there full time.Is this a sleeping platform for the JK in the background?
I like the way you hide the piano hinge along the seam. Most people put the hinge on the surface of the platform, which doesn't look as clean. I'll probably do a similar folding platform in my rig to allow seating over the front bed rail of the Gladiator. I'll also need vertical spacers between the platform and the folded down back seats of the Gladiator. Thanks for the pics.yes it is. It stays in there full time.
unfortunately I don’t really have any good pics of it installed. I have since lowered it from 7” to 3.5” to gain headroom.
Looks awesome... OEM from the outside!Still need to clean off some smudges, but I think it turned out pretty nice. I have a thin scratch in the paint, but it looks like the bottom fiberglass edge conceals it. I used flat black which looks like gloss from the outside of the vehicle and flat from the inside. What do you think?
