Yes - in this thread http://www.expeditionportal.com/for...ize-AWD-Van-Info-thread?p=2009917#post2009917
Is the stock stereo in the Express a standard Double DIN unit or GM-specific size? I want to replace my stock unit so I can hook up a backup cam, but the options Crutchfield is spitting out seem really limited. Anybody have the same experience? Any recommendations on a Double DIN stereo that fits well and has good resolution for the backup cam?
Isn't there a thread or a post where somebody wrote what wheels and tires...
I'm curious how these lift keys/kits will affect an AWD 2500 Van. All the same as the 1500 or do I need something totally different for mine?
Shoot I somehow forgot the white keys!My 2013 AWD 1500 Pass van came with the white keys stock, # 15592574...18 degrees...I had alot of bolt sticking out at stock height and could have got some lift, my alignment guy said I might not have needed the aftermarket keys with my new torsion bars.
I have found out that AWD 1500 Van brake calipers, pads and rotors are the same as similar year 1500 SUV and Trucks "except 07- up trucks with rear drums".......
Upper and lower front control arms are the same as 99-06 1500 SUV and Trucks, just like the front shocks. Good news for finding parts on the road far from home or just to make you feel better about the AWD 1500 van not being that rare........
The AWD 1500 Van frame is not shared with anything, most other parts yes and that is a good thing. The parts have been proven on other chassis and are easy to source new or old, part of my reason for choosing the AWD 1500 Van.
So this 15" travel kit should work with a few added truck parts thrown in!My 2013 AWD 1500 Pass van came with the white keys stock, # 15592574...18 degrees...I had alot of bolt sticking out at stock height and could have got some lift, my alignment guy said I might not have needed the aftermarket keys with my new torsion bars.
The AWD 2500 Van is the same 7300lb GVW van, no differences anybody has found to date.........
http://www.vegasdezertfab.com/product/1999-2006-chevy-4wd-silverado-1500-long-travel-suspension-kit
Even with coilovers it would cost less than the boulder offroad 6" kit.
I really need to find someone with a 1500 that is willing to let me borrow their truck for a weekend to compare/ measure front end parts! Anyone know somebody?:Mechanic:
- What is a real world MPG for highway driving? Stock suspension with a set of A/T tires.
- What are the most common and/or most expensive problems these vans have?
- What is the cargo capacity behind the first bench seat to the back doors? IE, will a sheet of plywood fit with one bench seat in place?
Curious what source you guys are using for part numbers?
I have found some very good OEM part's fische online for motorcycles but nothing too great for GM parts.
Hi guys, I have searched this thread and didn't find exactly what I was looking for. Wondering if someone can answer a few questions for me about the GM AWD vans.
- What is a real world MPG for highway driving? Stock suspension with a set of A/T tires. When I was stock I got 13-18 MPG, but I have 200k miles on the motor
- What are the most common and/or most expensive problems these vans have? I would say a semi common problem is when the 4L60E trans gets older they tend to have rough 1-2 shifts. The 2nd gear accumulator and or servo gets worn. The parts to fix it are cheap, but they require some expertise to install. But good news its a Chevy and this engine/transmission combination has been in millions of trucks/cars/vans so parts are cheap. The motors in these rigs are solid!
Thanks for your time and I'll keep reading in the mean time.
