has anyone installed extra seats
woodeye
Just bought a 02 tacoma extracab, short drives are fine for riding in the jump
seats but long trips like to Canada, my teenage daughters will flipout.
So if I add a cap and can safly secure two seats in the bed w/ seat belts, every one will be happy including the dog and all our gear.
Any suggests or links would be helpful. thanks
Woody:1888fbbd:
stevenmd
Jeep backseats are about the cheapest thing you will find. Make a bracket for them (the seat and seatbelts) to bolt to and weld/bolt the bracket to the bed. Presto.
Brian894x4
I wrestled with that idea for some time with my mini-truck.
There are a number of things to consider.
Ventelation is a real problem back there both in hot and cold weather. Side windows will help, but unless the windows are right next to them it will be pretty uncomfortable. There's also the issue of the exhaust, which is more likely to leak into the bed area due to it not be air sealed or ventelated like the cab is. And it will significantly louder than the cab, since there is no sound deadening materal. Some of that could be fixed.
Then there's the safety factor. You'll want to add a roll bar, because if you roll, the rear will have no protection whatsoever and they'll get crushed. Also, the canopy is likely to come off, which could cause further injury. Also, in the even of crash and fire or going into water or some other situation where one needs to get out quickly, the escape options are fairly limited while in the bed.
The seat belts need to be secured and drilling a hole through the bed just won't cut it as the bed sheetmetal is too think, IMO. A few large washers or some steel plate, might help as it least spreads the load out over a wider area.
And then there's head room. You'd be surprised at how little head room there is with a standard canopy, once you install seats. A high roof canopy will help.
This is just my opinion, but I personally just would not do it from a safety point of view. But if you properly secure the seats and belts and add a roll bar, such as maybe a used one from an older 4runner, it will be better than it could be.
Good luck.
DenCo40
Seats...
I added two rear facing seats in the back of my 02 Tacoma standard cab. I installed an old 4runner roll bar too just for extra protection. I installed seat belts as well. The main problem as others have said it is illegal as all get out in some states to let people ride in the back. I got the seats from Hunsaker sports. They are the old sand rail seats you used to see in the old dune buggies and stuff. It worked out great for a while but i eventually bought a double cab. If you are interested I can post some pics......
Lynn
Any chance you could find an old Subaru Brat in the junkyard? I always thought the handles would be nice when offroading...
The pic is the best I could find on a quick search, but it's missing the headrests;
DenCo40
seats..
Brat seats are big bucks IF you can find them. I thought about them when installed mine....
Martinjmpr
Wiffleball Batter
This is funny, just last week I was thinking that somebody should come up with a "seat pack" that you can slide into the back of a pickup when you need extra seating.
The problems, of course, would be with the safety rules and regs that would almost certainly make it illegal and dangerous.
It makes me again wish that some enterprising company like Toyota would realize that Chevy actually had a pretty good idea with the Avalanche, even though the avalanche is (a) too big, (b) ugly as hell and (c) way, way too thirsty, it seems to me that a Tacoma-sized Avalanche-type vehicle would be a great idea. It would be better than a double cab because you would have the ability to use the area behind the front seats as either cargo or passenger seating. With a double cab or a regular cab, you can have one or the other, but not both. And the double cab with the full bed is just way too long to be practical for anyone who lives in a city (which is probably the reason you don't see very many of them on the road.)
If Toyota would make a Tacoma-based Avalanche copy, I'd be the first one in line at the Toyota dealer to get one.
The other option would be a true panel truck or window panel with a completely flat deck and removable seats. Something like a mid-60's Suburban. Of course, you wouldn't quite have the load capacity of a pickup truck with the shell removed (for example, you couldn't put a motorcycle in unless you laid it on its side) but it would give you about 90% of the functionality of a truck but also the ability to carry at least 3-5 passengers.
woodeye
I actually did some thinking and had my daughter sit in the back and we came up with modifacations. Its not ideal but for various trips until I get a
slide-on, I'm going to slide the folding seat forward 3" and add some lower
back padding.
Thanks for the suggestions, my wife and the state didn't like that either.
Woody
BigAl
I just put a ford ranger 60/40split bench in my buddy's wrangler. He has 3 girls so he needed an extra seat. The ford bench mounting feet are basicaly level and would sit nicely in a truck bed. His even had a flip down center console:)
Clay
Here is a couple of pics of the cage we built for the back of my buddies truck so we could put a shell and a back seat on it. I'll take more pics of the final install if you like.
attachment.php
attachment.php
Box Rocket
I found this old thread while searching for something else but it seemed worthwhile to revive this to add some information.
As has been stated, you will want to check your local laws to see what is legal in your state.
IMO if done correctly this can be a safe mod. Simply bolting some seats through the sheetmetal floor of the bed will not be adequate. I added some some factory bucket seats to the back of my '03 DC. I built a frame for the seats to mount to. The seat rails are welded directly to the frame. As are the seat belts. The seat frame is bolted through the bed with large backing plates beneath the bed.
My observations after having this setup for a few months. It works great for my boys (ages 12 and 10), but with the topper on it is tight on headroom for adults. For ventilation, we open the sliding window of the cab and the sliding window at the front of the topper as well as the wing windows in the topper. I was suprised at the amount of airflow I'm getting through the front sliding window. Of course in bad weather, that might now work quite as well.
It hot summer months it can get a little warm under the topper but isn't too bad. I have aux power to the bed and have looked at adding a fan of some kind but haven't made that happen yet.
Additional safety items. Definitely a good idea to add a rollbar of somekind back there. I picked up a 1st Gen 4Runner rollbar that I will be installing. I will also be adding an additional front hoop right behind the cab that ties into the 4Runner bar. That will give me somewhere to attach some kind of bikini top for shade so I can use it with or without the topper on the truck.
a few pics of what I've got.
woodeye
Wow this is old. I solved this problem after owning the truck for a year, I bought an 02 4Runner. Made more sense
for the family,
Woody
Box Rocket
for the family,
Woody
That's great depending on the size of your family. I already have a DC taco so I have the same amount of seats you do in your 4Runner. Problem is I have 4 kids (two of them in car seats) When the whole family is along for the trip there just are not enough seats. Now I have seats for 7 with my family of 6.
mbauerus1
