Hi, i have a 2001 e350 dually Chinook RV, 21' at 9700 lbs. rear axle is roughly 6500lb. I bought an Action Van 4.5" front lift and once installed was going to have rear leaf springs made to raise rear, plus put on 235/85/16 tires.
Local shop informed me today the spring shop will not make custom springs to lift rear in-line with the front. So I am being told I need to use 4" blocks in the rear, but I am concerned about using 4" blocks on rear, even with proper install. Are my fears unfounded? ActionVan has done rear blocks in rigs like mine plus much bigger and says there has been no problems. I do know with blocks the upper plate will need to be modified so it doesn't puncture tire. I also have MorRyde Rubber Shackle system so not sure if that matters.
If blocks are problematic where can I get a leaf spring pack made as local place refuses? If I need leaf springs can I run blocks until leaf springs come in?
I am in VA and lifted vans/rv are not common here so shops think I am crazy in general. My goal for lift is just to get ground clearance and not to forge into crazy off camber stuff.
