Hood Blackout
Chili
On the paint prep, if the surface is good you should be able to get away with the following: wash the area with dishsoap (like dawn) to clean the surface and that should also remove any wax, mask off the desired section, scuff the paint with a scotch bright pad, clean off any residue, spray primer - let dry, spray paint - let dry. Light even coats.
You can wet sand in between if you want better results.
Antichrist
I still think paint is the way to go. I can think of only two reasons to use a decal;
1. you like spending more money than you need to
2. you're planning to remove it soon.
