Its a dream but a good dream !
This is a tool that I'm finishing up for the wood work on the truck. New "T" square system .Table will have storage and on the end a router insert.
Love the box truck idea. Quick and dirty! How does the box do being directly bolted to the frame? Torsionally will it be ok with frame flex?
The testing I did showed little deflection . But I did not try anything very big. Just up to what I would be interested in taking on. If what your going to be doing is over the top then look into 3 point or 4 ? Trying to be ready to go to Overland Expo 2018. Then maybe the Rover guy's will help put it through some tests ?
I know what my Wife is willing to do and that is no problem. That is the test for us.
No I'm going to stay in the US and maybe Canada ? Last time I left the US they gave me a gun.
I'm back at it. Maybe Tuesday I will cut the door opening. I have checked and checked and checked the numbers. So it must be where I need to cut but I'm still a little apprehensive.
Also needed to work out the pull out landing. It will be 30" w 49". Latter will be able to be put on all 3 sides.
Then its on to the bathroom. Going to use the C 223 CS cassette toilet.
And looking at a split Heat Pump system.
Yep. Part of it will be the wall for the bath. Welded 1 1/2 " x 1 1/2 " steel tubing for the frame. Will also act as a bulkhead.
Also got the slid for the pull out landing. Rated for 500 lbs. Will be about 30"+- and 48"+- long. Steps will mount to 3 sides. Also will have a pull out latter for boarding without the landing pulled out.
Has a lock for in and out.
ELShockley
