Its a dream but a good dream !
Awesome thank you! YEah a spare is a great idea, I was going to Get a Northstar 850sc, which comes with it. However I could not pass up the deal on this Outfitter Apex, so want to retrofit it. Your build looks awesome! I have thought of drooping a pop up camper on the LMTV frame.
  • Like
Reactions: B85
Almost walls ?
Riv-nut's at roof and bolt through at floor into steel cross member.
Making sure my water idea will work .
Yep.
With the wall only being 1 1/2"'s thick it maybe hard to do the cross over ? But I think it will work.
Need to take the hot and cold up to the mixer and then to the roof for the shower head.
Wall will be the pink 1 1/2" foam and will add spray foam to the line areas.
Have run the lines so whey will drain by them self when the drain valves are opened.
Not much thermo protection for freezing . 1/2"+ wall with glass both-sides and then maybe 1/2" foam.
Think I will just leave the heat on ? LOL
Wall frames up and now to finish install the box side door. Will pull it off again and seal it to the outside of the box with 5200.
Side door is reinstalled. What a PITA ! I love and hate 3M 5200. Hope I never need to pull that door. And who ever needs to do it is going to hate "ME" ! LOL
Now I need to build the shower pan ?
Bath window installed and sealed up.
Slow going. I have too many things on the stove but I have a side window coming ! This is a exit window with a screen slider window. Will build some kind of a push open and hold arm and some kind of inside screen ?side window.jpg
Getting back on the build and have been think about cutting the box down ?
She will not fit on my front yard without hanging over the sidewalk.
Not a big deal but would like to not park on the street.
From her 16' floor plan I would lose about 3'2"
The other plus is I would not need to do any thing to the frame. Just add a drop bumper.
Full timing? Two people?
Ours is 12'2 on the floor, plenty of space to full time for two IMO. with the kid, maybe not, I would want the cabover for some more storage. I'm sure it could be don't tho.
  • Like
Reactions: B85
ELShockley
