I am so glad the Farmtek was not an option for you as what you did looks so much more proper than anything other than real wood. Cheers to you on a well done job.
Weight is biggest concern for my rack, and following that, making sure that the flooring it tight enough so that it can be comfortably walked on with bare feet (as my veranda for my RTT!). How much does each board weigh at the cut length you have? I like the farmtek primarily because of the anticipated weight for the floor density it offers.
the teak effect looks great, I have the same rack on my D1, and I used a sheet of walk way board that looks alot like the chicken coop flooring mentioned earlier. Its the stuff with grit stuck to the top sor safety on elevated walkways (looks like a waffle)
It is Fibre glass (I think) and cut to fit where I want it, and secured with exhaust clamps to the rack.
That's what I like about the Farmtek flooring. Any time it's advantageous to attach a strap where I don't already have a cut out, I just use a pair of snips to cut out a rib and I'm ready to go. In the 5 or 6 years I've had mine in use I've cut out a number of them with no reduction in integrity.I did not like the fact that the grating would make it hard to attach rubber bungies to the metal frame of the roof rack under the grating. I wanted full and unrestriced access to all of the steel framework to have lots of flexibility in the way I attach my loads on the roof rack.
Peter, what kind of lights do you have on your rack? Will lights and flooring help the wind noise?
