mk216v
Der Chef der Fahrzeuge
Hi all,
Please bear with me here. I've searched the forums, asked trusted associates, and even SSBC's tech dept, and I still don't have a straight answer. Maybe someone here knows about 13" and 14" front rotors?(scroll to bottom of post for most simplified question)
Here's what I'm looking to do;
In looking for larger front brakes for VANdiana ('07 E350 6.0LTD w/ UJOR 4WD kit, using an '04 F350 SuperDuty 4x4 front axle...so 13" stock front rotors), I'm still shocked that no one makes a complete BBK; Baer nor SSBC nor AP Racing nor Brembo. I suppose their marketing dept's don't foresee that of ALL of the Ford vans/trucks manufactured, even a small majority (especially those towing) will need larger brakes? Anyways, moving off the soapbox...
So my two upgrade choices are the RSC 14.5" upgrade thru Chris at UJOR (~$4000, due to numerous upgraded components in front sups), or SSBC's 8piston front calipers/rotors/pads(~$1350 BBC3/ProfessorPaddle in Seattle has).
While I'd love the RSC, it's more than I want to spend currently. I figure I'll try the SSBC option first, so my question pertains to SSBC's offerings.
They state the 8pot front calipers use stock rotors and bolt to stock spindles;
http://ssbrakes.com/i-10093222-caliper-set-v8-quick-change-aluminum-caliper-upgrade-kit.html
Now when looking at the Big Bite rotor options, there are both a 13" and 14" rotor options available, depending on axle ratio.
Looking at the left rotors only here for comparison purposes;
13", SKU# 23541AA3L; for vehicles with 3.73 / 4.10 & 4.30 ratios built on or After 3-22-99
http://ssbrakes.com/i-10093189-rotor-big-bite-cross-drilled-slotted-left-front.html
14", SKU# 23540AA3L; for vehicles with 4.88 / 5.38 ratios built on or After 3-22-99
http://ssbrakes.com/i-10093185-rotor-big-bite-cross-drilled-slotted-left-front.html
Now my F350 front axle was a 3.73 so it makes sense I have 13" rotors.
So....if their 8pot calipers are for use with stock rotors(13" or 14"), AND bolt to stock spindles, then this tells me that EITHER the spindles are different from 3.73/4.10/4.30(13") and 4.88/5.38(14") rigs, but accept the same stock caliper--just push it farther out for the 14" setup(and hence maybe the spindles are interchangeable where I could upgrade to a 4.88 spindle and thus run 14" rotors??)...OR maybe the 3.73/etc and 4.88/etc spindles are the same BUT the caliper brackets for each spindle are unique(and hence I could upgrade to the 4.88 caliper brackets and run 14" rotors??).
Simplified question; on my '07 E350 6.0L, if I have 13" front rotors, can I upgrade to 14" rotors????
Thank you for any help,
Jeremy
Jeremy
