"Lola" - WreckDiver1321's 2005 Frontier CC/SB Nismo Build and Adventure Thread
Got my underhood wiring finalized!
It took me a while to get everything squared away, namely the relay block and interior wiring, but it's all sorted now. You can see I've made everything able to be disconnected, and everything is labeled. I've color-coded each circuit in a roundabout way. The wires going to the switch and the accessory are given a certain color that corresponds to the accessory. The fog light circuit is brown, the off road lights are yellow, the air compressor is blue, and the backup lights are green. The power and ground wires on the relay and the switch are all red and black, respectively. Everywhere the wires went, they were either taped or ran through wire conduit and secured with zip ties. I wanted everything to be as clean as possible. Turns out it's a lot of work!
I don't have anything connected to the compressor or backup light circuits yet, but the wires are in place for the accessory and the switch when it's time to add them. When I was done building this, I ran the wires through the firewall. The hole I used was already there from the factory and accommodated a grommet that was the perfect size for all the wires I needed to run into the cab (4 14AWG accessory wires, 1 14AWG power wire, and 1 CB radio cable).
After doing this, I installed my OTRATTW switches in the factory switch blanks.
I'm super happy with the way these turned out. It looks really clean, almost factory. If you're not looking for them, you'd never know they were there.
The quality of them is awesome. They make a very positive "click" when you flip them, and they illuminate when switched on. The symbols and writing on them isn't just painted, it's etched. My factory locker switch isn't even like that.
After I had installed the switches, it was time to tackle the wiring under the dash. I mounted a dual power bus and a small fuse box just below the dash on the driver's side. I ran the red power wire to the positive side of the bus and grounded the other side. I used these for the power and ground points for the switches. The fuse box sits in between the positive bus and the switch to prevent the switch getting fried. In this picture you can see the accessory wires coming into the cab and going to the switches (I don't have a reverse light switch, which is why the green wire goes nowhere.). You can also see the CB cable and the power wire going to the mounted Blue Sea dual bus.
I'm really happy with the way the wiring turned out. I think it looks pretty good, and it's very clean. Everything is organized and out of the way but easy to access if I need to. But now for the cool stuff...
The wiring allowed me to add a set of Hella Rallye 4000 auxiliary lamps. I got one Euro beam (driving pattern; kind of wide and long distance)...
...and one cornering beam (spread beam pattern; wide and short distance)
This setup gives me the best of both worlds. I have a very wide light that gives me vision off to the sides of the road, and I get some enhanced distance vision. The cornering beams nearly triple the distance I can see side to side, and the Euro beams just about double my visible range. Perfect for the kind of conditions I'll be driving in at night, where deer and elk are the most common problems.
These lights are extraordinarily well made. The housings are very nicely coated, and the beam adjustment system is pretty clever. My only complaint is that the cornering beam came with a plug for the wiring pigtail, whereas the Euro beam simply had the wiring come out of a rubber grommet on the back of the light. A very minor annoyance, but it's there. Otherwise they are fantastic. I'm really pleased with the overall quality from them, and their light output is awfully hard to beat.
To protect the lenses from damage, I got a set of these clear acrylic covers. With these, I don't have to worry about uncovering the lamps when I want to use them or about impact damage. Plus they look pretty cool :)
These lights really cool on the truck. They are a pretty good size at 8.75", although they are kind of dwarfed by my large ARB bumper. But they definitely add a bit of the touring/overland style.
So here's what I now have for lighting!:
1. Headlights
2. Fog lamps
3. Hellas
I'm pretty stoked to try these out on the deer infested side roads up north!
Nice work on the wiring, doing it right like that really does take the time; but in a few years when you don't have to rip it all out and redo it, it'll pay off. I actually think the Hellas are a good proportion to the bumper, they're very well matched size-wise (IMO).
Great choice for lights! Can't wait to see how they perform.
Thanks! I'll be getting some beam shots tonight.
Yeah, I figure I've got about 12-15 hours in wiring, but I'm really happy with the results. This was my first ever major wiring job, but I worked slowly and methodically and the results are awesome. I'm really happy I took the time to do it this way and I know I won't be hating myself later on down the road when I want to add or change accessories.
Don't get me wrong, I think the lights look awesome on there. I'm very happy with the look in the end. Very Aussie touring style, and the light output is phenomenal. They finish off the front end quite nicely. Just need a winch now :D
Okay, got some night shots of the new lighting. Seeing it like this really drives it home for me. I'm super happy with my choice in lights. Having the combo setup with two different beam styles has given me a really nice all-around lighting solution. So, here are the shots. I found a long, straight stretch of road to light up, and it was one of the darkest nights in a long time tonight.
Here's the low beams.
High beams.
High beams with the ARB/IPF fog lights.
And now with the Hellas.
You can see the Rallye 4000s throw an awesome amount of light out. With the Euro beam and the cornering beam I get quite a bit of added distance, plus the side-to-side spread of light is just incredible. I am lighting up things at about a 75* angle on either side of the light. For the deer infested backroads I often find myself on at night, it's a pretty good solution I think.
Looking good buddy!
That tent looks nice and roomy.
Can you stand up in it? Looks like it would be close for a 6 footer like me.
"It's HUGE!!" ... only need to watch through about 0:28 or so ... but, it comes back to the topic at the end if you stick around for the full 1:37.
But seriously, that looks like a downright bombproof tent ... I'm sure it'll even do mild winter or late fall/early spring stuff if you're so inclined. How's the weight? I wish they'd found a way to at least make the packed configuration shorter ... it's a bummer it has to be stowed/transported on your roof rack. It would be nice if you could get it into the truck bed.
Looking good buddy!
Thanks Mike!
Yeah, it sure is a nice sized tent. It's not quite large enough to stand in for me. I'm 6'1" and it's a bit too short.
Hahahaha great video.
It really is one of the most well made tent's I've ever seen. The sheer amount of thought and engineering put into it is just awesome. It actually does seem to insulate fairly well, and there is space to put one of these guys: http://www.amazon.com/Mr-Heater-F232000-Indoor-Safe-Portable/dp/B002G51BZU/ref=sr_1_1?ie=UTF8&qid=1431371586&sr=8-1&keywords=buddy+heater. I'm planning on getting one to increase our camping season. The tent and my bedding solution should keep us quite warm!
It's not light, that's for sure. Like around 45lbs. But it's not too bad, seeing as how I hardly ever set up camp more than a few feet from my truck. Honestly, I think the weight is kind of a non-issue for how I camp. As for the size... yes, it's big. But I don't mind at all carrying it on my roof. It's not so overly large that it adds a bunch of wind resistance like some RTTs, so I really doubt it's going to hurt mileage/range at all, and getting it up and down from the rack is pretty easy to be honest. The bag is pretty heavy duty, so I'm not worried about wear on that either. The only thing I don't like about it is the weight, but even that doesn't really bug me. Like I said, can't wait to get it out in the wild.
Alright, time to query the ExPo Nissan club. I'm looking at a really minor mod and not sure which direction to go with it. I want to add some mudflaps to my truck, like a larger rally style set. I did some digging around and found Rally Armor mudflaps. Looks like good stuff and good quality, then I stumbled on this picture:
These mudflaps are pretty different, but I think I might like this idea. My truck is all black, and these would help break up the darkness a bit. Plus apparently I'm going for a kind of black with red accents kind of thing. I've got a red antenna, I'm going to do red tow hooks under the front bumper, and red skid plates. I think it would add some pop to the truck and tie the red accents together.
What does ExPo think? I know it's all kind of subjective, but I was just wondering what other people thought about them before I pull the trigger.
The red doesn't look too bad, I think its one of those things you would have to see in person to make a full judgement.
Be curious to see the Hellas compared to my lf240s.
I am as well. I was looking at the LightForce 240s, but was swayed by the price and altogether great reviews I had read on the Hella 4000s. I spent a lot of time over on candlepowerforums.com asking for opinions and reading past information. I really doubt my Hellas will have the range your LFs do; mine are a driving beam and a spread beam. But I get double my high beam range with the driving beam and a stupid amount of side to side illumination from the spread beam. That's more than enough for me!
I would agree with that. Leaning more towards the red all the time.
Jlbeats
