Lucky 8’s Project P38
That snorkel looks very clean. Anxious to see how you will plumb it into the airbox. Looks like the top edge of the hood needs to be chopped off. Any problems with water drainage around the drivers side blower motor? Looks like that area may be more exposed now.
Are you selling the Ashcroft diff and heavy duty axles?
We used flexible tubing from the snorkel all the way into the airbox. After I get the truck cleaned up from Conclave I'll take some more pictures and post them up. We have the ATB diffs and HD axles in stock.
What sort of turn-around time do you think you're looking at before the snorkel is available as a production run? :)
Project update : The space inside
In my opinion the P38 is smaller on the inside when compared to its brothers of the same generation. Finding room to tuck away things is difficult and the lack of aftermarket support makes add ons virtually nonexistent. The issue was finding a good place to mount Carling switches. We needed them to be easy-to-use and convenient to see. Our first idea was to put them in the dash where the original fog light switches are. Unfortunately the Carling switches are larger. With our options limited we hit the shelves and this is what we came up with.
For those of you that don't know, Mud UK produces an accessory pod they call a MUD POD. The MUD POD is designed to sit on the dash of a Defender. The Defender's dash top has a cut-out for an ashtray. The MUD POD utilizes the ashtray hole for mounting and the hole also provides a way to run the wires discreetly behind the dash. The P38 does not have said hole but we will get to that in a minute. The MUD POD comes in two sizes.
Full Size
Or Mini
Just out of curiosity which one do you guys think looks better?
We opted for the full size MUD POD. This gives us the ability to put in as many switches as we like. It also provided additional space for USB ports.
You can never have enough USB ports and we used every one during the VOT.
In order to run wires up to the Mud Pod you need to remove the instrument cluster and In this spot drill at an angle towards the cluster.
If you're going to attempt this please believe me, use the utmost amount of caution. There's A labyrinth of ductwork beneath the dash
Here's the view from the rear seat of the final instal and it kept all of the devices charged during the VOT.
For some extra storage space we looked to the spare tire well that was no longer in use.
Believe it or not there was room to stick two chairs in there.
Followed by a three second Malamoo tent.
And finally an Oz tent shower. It all fit perfectly in the spare tire well.
Poser pic on the RTI ramp at Conclave
The full size pod looks much better, the mini doesnt look in place covering a fraction of the dent in the dash.
The truck is looking grate!!
Hey Justin i Just order the new rear panhard bar...was wandering just how much adjustment there is over the stock length
Mini Project update : Covering our Gassets
The stock fuel tank holder was getting scuffed and it was just a matter of time before we ripped through it.
With Rovers on the Rocks just a few weeks away it was a perfect time for the Terrafirma tank guard to show up.
The TF unit bolted into place like a dream. All we did to prep for the instal was run it low on fuel.
The tank guard is available here.
http://www.lucky8llc.com/Products.aspx?ProductID=7889
Poser pic from last years Rovers on the Rocks
Great product great pics, thanks! a shame shipping to Argentina would make it prohibitive.
Any news from the snorkel? Hope its light!
Project Update : A biff, A bash, but never a crash
Last weeks adventures during Rovers on the Rocks tested all of the armor and gave the Ashcroft ATB a full on work out.
A Biff
Before we get to the rock challenge lets have a look at the brand new front steering guard from Terrfirma.
I was planing on taking some action shots with the guard during Rovers on the Rocks but with in the first few minutes the guard was put to the test.
The new guard fit with ease and was able to take the abuse.
A Bash
The steering guard was not the only new piece of armor earning its salt. The tank guard took a beating.
With out the guard the gas tank would not have survived this.
http://www.youtube.com/watch?v=3Iar726Zl8Q&feature=c4-overview&list=UUUnCLXtAqip_9qd-T1NenbA
Never a crash
The P38 performed amazingly and this was partly due to the Terrafirma beed locks. I aired them down to 8psi and they gave us all the grip we could possibly ask for.
Traction can be a double edged sword. If the tire has more grip then the drivetrain has strength to spin it two things can happen.
1 the motor bogs down and wants to die
2 the weakest link in the system does its best rice crispy impression “Snap Crackle Pop"
Yep you guest it we went with choice number two. The 4 dot 6 combined with the sticky icky Nitto's ended in Snap Crackle Pop. We are betting it is the front viscous 1/2 shaft in the transfer case. Unfortunately this neutered the front drivetrain leaving us in rear wheel drive only. The silver lining in this failure is we were able to see just how good the Ashcroft ATB is.
This situation gave us a unique oppertunity to see the ATB in action. With the traction control disabled and no power going to the front wheels this was a perfect challenge. Could the Ashcroft unit provide enough torque transfer to the one rear wheel on the ground to push the front two wheels over the rock and dirt mound?
http://www.youtube.com/watch?v=bhdpSW9tRBw&feature=c4-overview&list=UUUnCLXtAqip_9qd-T1NenbA
My hats off to the ATB. If the traction control was working, I'm betting it would have walked right out with very little effort.
Before we get to the poser picture I have two other pictures I would like to share. The first one is of the Mud pod. I am really liking this on the dash.
And the other picture is of the snorkel. We had a few water crossings and for the first time in a long time I took the P38 back with a dry air filter.
Finally the poser pic.
Very impressive stuff.
The protections look great! But already knowing than shipping to Argentina from any other part of the world is going to be too expensive we are designing and making a few sets of our own.
That snorkel is looking good, hope it's on sale soon!
I saw the ATB video first and thought, oh well, that is not so good. And then I came and read your post, and now knowing that the truck was on RWD and no TC! That thing not being a locker is doing a great job.
You are getting close to your goals now. There is not much left to do on that truck, and that is sad, I would have liked this thread to go on forever.
LukeSkywalker515
