LX470 Lift Opinions
I was 1000 pounds over on wheeling trips with the ahc and never had a issue. It did 80,000 miles that way on 33's. Its lifted 2" now, and it aligns to stock spec with 35's, no UCA's. people ran this way without issue before the UCA's arrived o the scene. They are most expensive 1" of IFS droop you'll ever buy. A solution in search of a problem.
I advise to buy the basic lift IF you intend on 35's, and nothing more unless there is an actual issue.
Maybe it's because I'm at home sick today, but this reply is really confusing me. Who are you advising and who in this thread has mentioned 35s?
its a forum. someone searching information may read this and think UCA's are necessary for a lift and they are not. some people worry about the load on the AHC, and im letting searchers know its not to be feared, age is more the factor than potential load. i'm telling readers what is actually needed and at what point. some trucks do seem to vary, naturally.
Thanks. There are a few advantages to the OME lift. The first is that you're moving from a fairly complicated (although incredibly robust system compared to equivalent LR offering) hydraulic suspension system to a very simple and therefore more reliable traditional setup. Moreover, if something breaks on the OME setup, you can probably come up with some kind of field repair in a small town. Good luck with that if your AHC globes go.
But the better reason from my perspective is that the AHC system just isn't designed to take the weight of a fully loaded vehicle that's also a bunch of extra weight added to it (bumpers, sliders, roof rack, etc). There's been some discussion about getting upgraded coils and torsion bars from Australia, but there doesn't seem to be much experience with this. And even with upgraded hardware, you're still probably under-damped with the AHC system. Going with the tried and true OME setup was the path of least resistance after looking at all my options.
Personally, I never used the low setting on the AHC and so all I really lost was the ability to go from N to H. Now it's just like I'm in H mode all the time. And while the suspension is definitely stiffer than the AHC was, I don't find it too stiff and I really enjoy the reduced body roll when turning.
Great information! I just bought an 03' and the AHC system is working fine. As soon as it goes....OME here we come.
Whats your future plans for the LX470 do you have?
I have a build thread that I keep up to date (more or less) on mud: http://forum.ih8mud.com/threads/texascrane-build-thread.885390/ I've done a fair amount to the truck since I started this thread last year.
There are really 2 items that I'd like to get finished in the near future. The first is finally getting my ham radio installed. I've got the last part that I need showing up tomorrow afternoon, so hopefully I'll have some time this week to get it all installed.
The second is finally getting a second battery installed. I've been sitting on this for a few months waiting to see what Slee was going to offer (the old solution wouldn't work with the arb twin compressor, which I've got). They just released their new dual battery solution that does work with the ARB twin compressor, but unfortunately it uses a group 75 battery - which is only a 50AH battery. I would really like to get something that will hold a northstar 27f battery. It's the stock size and 91AH. I'm torn between the "easy" solution from Slee or seeing if I can find somebody that can fab a custom solution for me without it costing an arm and a leg. Unfortunately I don't have the ability to really fabricate something like this myself. I've had some casual conversations with a couple of shops, but I need to make a decision and move forward soon.
5mouse
