Mark's DC Tacoma
mountainpete said:
Looks great!
What size did you end up going with in the end? Any rubbing yet?
I ended up going with 285/75's. So I have more clearance where it counts. And while in baja this last weekend (here) I learned that jumping my truck with these wheels - they stuff into the wheel well and rub almost half of the plastic wells. I also rub when at full lock turning left, but not right.
Rob...Thanks for the kind words :) It was a pleasure meeting you and your family. It's great to see you guys enjoying life! But you know what really trips me out is how you earn vacation, dammit!
dual battery setup
blupaddler said:
I never got to finish talking to you more about your dual battery. Could you expand on this a little? Also who made your battery strap down? That thing was stout!
:clapsmile
Well I don't think I've elaborated on my dual battery setup and since Rob put me on front street I guess it's time :)
Key Components...
main battery - odyssey 1200mjt
aux battery - odyssey 1700mjt (battery specs)
mobi-arc isolator (more info here, and tech specs here)
Rockford Fosgate 1/0 cable for the (+) and 2/0 for the (-)
I only used 2/0 because we had some left overs at work
Rockford Fostgate positive battery post lugs
I'll try and keep this as organized as possible so forgive me if I ramble...
My reasons for choosing the 'perfect switch' is efficiency, reliability, and the theory behind the isolator works for my application.
Efficiency/Reliability
There are a couple ways of isolating batteries...
1. Solenoid - You can find these in your winch. Essentially they are contacts that open and close, isolating and combining your batteries, respectively. Solenoids are rated for interrupting large amounts of current that's why they are found on your winch and with battery systems. When contacts open and break excessive amounts of current a layer of oxidation builds on the current carrying contacts. This layer of oxidation creates resistance. Resistance reduces efficiency. In turn making it harder for your alternator to fully charge your batteries. Also say when you combine your batteries to winch, the battery that has to power the winch through the solenoid will waste power because of the solenoid. And I hear occassional stories of solenoid failure with winches. Maybe because it's not only electrical but mechanical as well.
2. Diodes - such as the surepower isolator. Diodes by nature waste power (watts). Typical diode isolators drop the voltage by 0.7 volts, I know it doesn't sound like much but at high currents the losses add up. Power (watts) = I (current) x E (voltage) So let's say you're winching and the winch is drawing 200 amps.
140 watts = 200 amps x 0.7 volts. What this means is at a loss of .7 volts, and 200 amps of current flowing you're wasting (losing) 140 watts. This loss of electrical energy becomes energy in the form of heat. That's why the diode type isolators are larger and have heat fins. As heat rises, the resistance rises, and excessive heat can cause premature failure.
3. MOSFETs - this is what mobi-arc uses. The electrical theory is a little too deep for me but I've actually tested my isolator to see if what they advertise is true. I didn't write down the numbers but what I did was hooked up the winch to draw current from both batteries (not how I would typically use it, I'll explain later). With a clamp on DC ammeter I measured how much current was flowing through the isolator. I think about 120 amps were going through the isolator. I then measured what the voltage was before and after the isolator and it was a difference of about .04 volts. So with the same P = IE equation that equals 120 amps x .04 volts = 4.8 watts.
Now I know it's not a whole lot of power, I think I'm just critical about it because electricity is what I deal with every day. But think about this - would 140 watts of heat or 4.8 watts of heat be easier to dissapate? Hence the reason why the perfect switch is smaller and doesn't need heat sinks. Another benefit of this type of isolator is that it's solid state, there are no moving parts = less things to break.
How it works...
I have the Single Rectifier Unit, (think direction or current flow)which isolates the main battery from the aux battery. It does NOT isolate the aux battery from the main battery.
Another way of saying this is the aux battery can and is feeding the main battery as well as everything connected to the main battery. In contrary the main battery cannot feed the aux battery.
Essentially what this means is, anything fed from your aux battery will only take power from your aux battery, your main battery will be untouched. Now anything fed from your main battery will be fed from your main battery and your aux battery via the isolator.
Now because it is designed this way, the main battery will never have a lesser charge than the aux battery. Why? Because the isolator allows the current to flow from the aux battery to the main battery, but not in the opposite direction. So it's like the aux battery is always jump starting the main battery. That's why the main battery will always have a greater charge than the aux, so it's a guarantee that I will be able to start my truck.
So here's the jist of what's connected to my aux battery..
1 fridge
multiple 12v outlets
3 lightforce lights
4 rock lights
2m
cb
air compressor
winch
All of these accessories take power from the aux battery and the aux battery only. These are the accessories that have a greater chance of draining a battery, either over long periods (fridge camping) or short one's (extensive winching).
Why don't I combine my batteries for winching?
I haven't done too much winching but after talking to many many people, one good battery is enough. I don't frequent anything too extreme and even if I did, I could always use jumper cables to combine the batteries. And if I did an extreme winch pull and killed a battery, it would be my aux battery and not my starting (main) battery.
If I did use a system that would combine the batteries and did a crazy winch pull that killed both batteries - then what? Drive around for an hour to make sure your batteries are somewhat charged. Chances are slim but I don't want to take that risk.
Now let's say you use your radio while camping a lot (which would be connected to your main battery), there's always the possiblity of killing your main battery and your aux battery. I typically don't use my radio or anything wired from the main battery, while at camp. If you do use a lot of factory wired accessories when the truck is off then this may not be the choice for you... If I do choose to listen to xm at camp I'm not afraid to because the current draw is so minimal and slow that I can catch the battery before it's too late with a voltmeter.
Whew, that was long winded. Clear as mud? I hope I helped people more than I confused people :(
Yes, pictures are coming...and I'll try to put together a drawing for the visual learner.
Oh and the mount was designed by me and made by John at Demello's. I love that hold down/isolator mount!
Fire off any questions, I'll try to clarify...
Good thing I have seen it in person or you would have lost me!
Oh yeah... Want to trade trucks?
Oh man, those Chamber wheels look just freaking awesome on your truck. IMO, those are hands down the best looking wheel around right now. Too bad they don't make them in white - I think that would look really cool on a white truck. The black look fantastic too - I can't wait to see them on Scott's truck.
Excellent post you just did on the aux. battery system. Very well said and I "got" every word of it, and agree. Pretty cool that you actually tested the unit you have. 4.3 watts - that's impressive!
LOL, sure we can trade, just leave the TwoZone in there! And all those goodies you say have layin around!
Thanks for the compliments :elkgrin:
Those in flat white, on a white truck would look crazy. Almost like a retro look. I've loved gun metal finish for years, I couldn't wait for somebody to make truck rims in that finish. Well teflon is close enough to gun metal :rolleyes:
Ramblings from my last outing...
The ten leaf deaver pack really isn't strong enough for a heavy taco. I should have talked to others before I had mine rebuilt. My rear end was sagging pretty good, and I was only loaded for a 3 day trip. I bottomed out hard a couple times on my rear end, I'm sure it wouldn't have happened if I didn't have anything in the bed. Right now I can't afford another leaf pack so I'll have to figure out something else in the meantime...
Hey, Mark! Did you get my email about ExTrophy and the Yakima basket? Might help you with the Deaver problem. :littlefriend:
Here's a picture of the battery hold down and isolator mount. I came up with the design and John from DO fabbed it up. The battery tray is the steel one that odyssey makes. I had it welded to the stock location and the quality of the weld didn't meet my expectations so I had to reinforce it with this. The hold down bolts on the side of the battery to the battery tray, the side of the fender, the factory j bolt and the other factory bolt above the headlight.
And those washboard roads in baja are no joke. That's the culprit of the missing screw holding down the isolator - time for some loctite.
Hey Mark, I have a few questions for you.
1. Do you have aftermarket upper a-arms?
2. How much room is there between the tire (285) and the UCA?
Thanks man :)
I had mine rebuilt to a 10-pack early this last summer and the trip I just got back from was the first real test of the 10-pack. I had all my gear, 25 gallons of water, 5 galls of gas, 100qt cooler full, 2 cases of beer, etc, etc. (basically the most weight I've had in it) and it rode almost level, much better than the 9 pack did, still not ideal though. Like you, I'm going to stick with mine a while and see how I feel after a year or so. I will probably change later down the road.
Thanks man :)
1. Not YET :D
2. It's really really close, I'll give a more detailed answer later today.
Thinking about snow chain fitment?
Our load is probably similar. I think in the meantime I'll put some shackles to regain the lost height, but I think the real solution is a larger pack.
Lift figures
Mlachica,
I'm currious to know what your current lift height is as compared to the stock figures? Just for the sake of having the info all in one place, Scott's truck sits 2.25" over stock in the front and 3" in the rear and BajaTaco sits 2.5" to 2.75" over stock in the front, not sure for the rear of his Tacoma but I'd suspect relatively the same or higher than the front.
Cheers :beer:,
P
HButton
