Mounting a 13" / group 31 battery to frame rail
jamesm113
Is there battery box / tray that would fit a 13" wide group 31 battery? Trying to mount one or two group 31 batteries to the frame rail of my chevy express.
I've searched everywhere I can think to look, and can only find trays that would fit a 11" wide group 24 battery like this one
Thanks
Go to remybattery.com. That’s where I got my group 31 battery trays. Pretty stout, too.
I mounted an AGM sideways to my frame rail of my Nissan, it was the right width to tuck in there nicely.
The enclosure is a metal electrical junction box, open top, drilled to drain if it gets wet, lined with 1/4" ply where the poles are.
The whole box sits in an "L" shaped tray framed out of angle steel welded together with some diagonal bracing on the front & back ends.
It resembles the link in the first post, but is totally enclosed. All that bolts through the fame, much easier when it is positioned with a floor jack.
It comes down every year or so to have the silt cleaned out, otherwise it stays put and does what I need without complaint.
Lots of medium duty delivery trucks use frame mounted battery shelves (lacking a better word)... hit a salvage yard with a tape measure?
Was hoping to avoid welding as I don't have a welder or access to one. Where I am, it's probably $200+ to just get a welder to show up.
The bolt on tray was attractive in that it was fairly inexpensive, just wished it was 2 inches wider so it'd fit a 13" wide group 31 battery instead of an 11" wide group 24 battery.
Yeah, the chevy express has a tray, but it only fits a 10.25" wide group 34/78 (or group 24dc) battery. Also, closest pick n pull is 100 miles away.
I too am going to mount batteries to the frame; see thread and post link below for the trays I purchased after I read SBaircraft's battery tray install. However, I am now considering going with lithium as the prices are dropping and the charge times are much faster. Wanting to use the van as a mobile office when off on an adventure.
@Willsfree Looks like those are group 24 battery trays as well... That sure is a sweet build though!!
Couldn't find anything in that style for group 31's on summit racing ?
Why do you want the group 31 batteries? What voltage/amp hour capacity are you wanting? Lots of threads on here recommend using two 6 volt group GC2 as a value solution for house battery set up. A lithium would be more compact/lighter per amp hour as well.
I want to get refurbished batteries from the local interstate dealer. The group 24DC's are $47 (82 AH), group 31DC's are $53 (98 AH). So there's a minimal price difference for the group 31, provided I can find an easy way to mount it.
Long term, I want to power a .88AH ARB fridge over 4-5 days. 2 Group 31's would get me pretty close to a full 5 days of running the fridge.
You could also build one out of the perforated angle from the home center, or maybe find a tractor battery tray at a farm supply, or even make one out of wood if you wanted to. Lots of solutions to this issue... even just buying one.
FWIW
"The Torklift International HiddenPower is a specially designed and convenient auxiliary under vehicle battery mount for all types of Group 24, 27 and 31 12-volt batteries such as lead acid, AGM, sealed, gel cell etc. This secure RV battery box is engineered as no-drill installations with quick disconnect electrical connectors, the system quickly attaches to the truck's frame under your truck."
https://www.torklift.com/rv/hiddenpower
2eleven
