My 2000 4runner. Linked, Locked, ADDICTED!
Yet another Beauty of a rig mate...
Curious about a few things.
1) Why run such a difference in F/R axle widths??? Maybe it's just the angle of the rirst pics, but it looks odd with the wider front track. Seems the stability of the rig could be helped with a matching rear width. Does it have to do with the leverage ratio and flex of different suspension cycles front to rear??? In my head I'm amaginiibng that the way you're set up the front end would have a leverage advantage over the rear and would then cause the rear to flex harder, maybe I'm off so that's why I ask...
2) WHat ever happened to the 4BT Mini-truck you were building??? Loved that build you had going over on Yotatech.
Cheers
Dave
The front is 66". The rear is 64.5"
A 1.5" difference is actually factory spec on just about every vehicle of every make that rolls out of the factory. The front is always 1"-1.5" wider to help with tracking and turning. Your 4runner front is 58.5". The rear is 57".
That 4BT rig was a buddy's. He ended up just parting it out. I built an 85' 4runner for him instead a couple years ago.
See, ya learn something new every day :D Thanks for the reply mate. I can see the advantage in a narower rear track in terms of trailing and roll forces. Seems the rear tires would "scrub" less I guess???
Sorry to hear the 4BT MINI never made it out of the shop, that was a neat build I thought. Still I've got a soft spot for 1st Gen Runners eh ;)
Again, this 3rd Gen looks AWESOME. So low key for how ultimately capable it really is. I LOVE the low lift, big tire idea. The lower the better.
Cheers
Dave
Rory Desjardin from www.RADesignsproducts.com was kind enough to send me one of his triple shifters as a prototype testing platform. I must say that this kit is pretty damn simple to install. It will require minor cutting of the transmission tunnel, but I sure do wish this kit would have been available when I started my build.
It went together seamlessly and the only reason I cut out the center portion was to make it easier for me to bolt the linkage on. Trust me, I did NOT want to have to drop the t-cases as that requires pulling the entire front suspension out, so working from the top was much easier. Also, simply cutting an access panel for the shifters and using some 18 gauge steel as the panel was simple.
The kit comes with everything you will need except some RTV.
I still at this point have to trim up on the portion of the center console to fit, but I will at least have access to one cup holder again, which IMO is critical. After all, you might spill your drink!
Okay, here is some fun tech that is completely off base.
My pop-up trailer is a decent size, and for the most part it sleeps everyone just fine. Problem is that when I have the whole family with me in the 4runner, there isn't any room for storage left in it with the three rows filled up. The pop-up only holds so much as well. So, I have been wanting to stretch the tongue on the camper a few feet to make more room for carrying stuff.
Also, the tires on the camper are 20" tires. They are tiny, and even with an axle flip, there isn't enough clearance. Especially with the added length I want to add.
So, here are the pop-up's new shoes. I found a set of stock Jeep steel wheels. They are 15x7" with 4.5-5" backspacing. Perfect for what I need. The tires are some Toyo touring tires that I found at the pic-n-pull for $15/ea and they are pretty much brand new. 205/75/15 tires. They measure out around 27" tall. So, the tires alone will give 3.5" of lift. Problem is that I will need additional lift just to clear them. I will add more about that when I get to start modifying it.
Today I started the frame hack. It was sawzall time!
What I started with:
Tongue weight of 150lbs without the propane tank and battery on the front.
Frame extended 36" up front
The box will be 78"x36"
New Tongue weight of 230lbs with the propane tank on the front. That would add around 40lbs
This is the only concern. The crank mount to the front, so I will need to make sure I leave access to it when the box is full built.
I plan on building the rest of the box next week. The rack itself is only tacked in place since I need to add some bracing to the frame before its fully welded on.
So, I got the tires on it. I built some custom spring hangers since finding u-bolts to fit a 1.75" tube that were long enough was going to be impossible. So, I took a page from my old All-Pro days and built some custom perches that allow me to bolt the springs on.
So, I have about 24" of ground clearance now. So, I feel pretty confident that I can get this trailer pretty much wherever I need to get it. It should definitely make for some interesting campsites at this point.
I still need to finish the front deck portion to add some side rails and stuff and potentially an 12V jack for the tongue.
Well, since nobody has been serious about buying the 4runner, I said screw it. So, I've decided to rework a few things.
First of all is a way to carry the spare. So, we cut off the old rear bumper.
Its still going to be a combo of plate and tubing, but will have a bombproof, dual sheer spindle on it.
attachment.php
attachment.php
attachment.php
attachment.php
We have the same wheels, although mine are black! I just read through your whole thread, very nice build and great work!
Some more progress on the carrier.
I went back and forth about 10 times on whether or not to keep working with it. It was too far away from the body at first, so I decided to switch up the spindle design a little.
This is what we came up with before leaving tonight. Its growing on me. Its obviously a VERY similar design to the original bumper, just a little less departure angle. But we sucked it up as tight as we could get it.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Man. I have the same 1999 2wd you started with and I must say this build is making me want to keep my Runner and build it instead of buying a new Jeep Rubicon unlimited. Very sweet build and I'm very excited about this tire carrier!!
Great Job!!
Kevin
Getting close. A few more things to do before its pulled, welded, and painted.
1st pic shows the 1" diameter bolt that will eventually be a twist in T handle. Its sleeved with 1.5 x .250 wall DOM through the swing arm, and lower portion of the bumper.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Looks good! You need a tire cover for the spare that has your shops name on it since the tire now blocks the sticker on the back window!
Bobbyjr
