Need help with a battery issue in my 04 LJ.
Sears Diehard Platinum is actually an Odysea battery , and the other thing i saw in your first post " you push the gas couple times,,,, wont do anything to help it start as it is fuel injected
It's ALIVE!!
The Platinum is in and the Jeep is running strong! :wings:
Thanks for all of the help!
Actually it DOES help starting and keep the enine idling when battery voltage is too low to allow a "normal" start and idle on a Jeep......not enough battery power to do what it's supposed to do.
So it looks like the alternator is good. it's running at 13.6 to 13.8 volts after starting. after a 5+ min drive it was running at 13.8 volts. A quick drive over to AutoZone and they are telling me it's at 86% and won't take a charge. so now ordering a new battery.
T
That's thecorrect charging voltage on a Jeep with PCM controlled charging........Also the PCM or any other on board charge regulator won't ever charge up the battery to 100% or near there.....you need a correct multi-stage battery charger to do that - especially on a AGM batter like the Optima............. 86% , that's over about 12.5 Volts, should start your Jeep easily!
OchoSolo
