New guy with gen3 montero
Marutuk
KK6WFB
I run 255/85/16 on my monty, but my spare isn't that size. I am not quite sure if it'll fit properly too due to the indentation. Maybe with a different tire carrier it'd work however.
cnutco
You will need to build an extender. I used some scrap steel for mine.
MascotRejct
That it is, drivers side pre-cat. I ended up clipping the wires. It was a pain! My problem was every time it would loosin up i would give it another turn and it would get tight again.
Now i feel stupid for not thinking of clipping the wires off... Damn. Haha
iin10ded
just scanned through this since i'm looking for a monty. fyi the radio whine can often be caused [or exacerbated] by the varying ground planes the radio sees - there are usually 3: via the metal to metal contact from radio chassis to car chassis [if you bolted / screwed metal to metal], the antenna mount will usually have a ground connection where it mounts to metal, and the actual wiring harness ground wire.
try lifting [sorry.. disconnecting] 1 or 2 [obviously you need at least 1..] but oftentimes just changing the ground can help with noise. pull the radio out of the chassis, and unplug the radio antenna - if the noise changes you're on to something.
jhill15
Good stuff man, thanks! What year monty are you looking for and where are you located? Theres a monteros on craigslist thread on here that might help.
jhill15
I picked up this first aid kit from sams club for my rig.
326 pieces for $20
Djbenny
Nice! And it's a new and improved design!!! Ha ha. Hey I started my own thread if you would like to follow. I'd be honored!
jhill15
Man the case is pretty nice. I'm thinking about taking the compartment. ..thing on the right side of the rear gate off and attaching the first aid kit in its place. Its too big to fit where in the net where the headrest go and I'd like to have it in a permanent spot. Thats one thing I liked about my X, was the kit on the hatch door.
I saw that, man thats awesome!
Already subscribed!!!
Marutuk
KK6WFB
Have a look at Imnosaint's build page, he did a really nice mod for his rear door including a way to hang up a case for first aid supplies (shame that Michel took the case, have to find one that fits).
Also don't forget to get a fire extinguisher for your car. :)
jhill15
I totally dig what he did with his rear gate, as well as the rest of his rig. I'm gonna attempt to strap this thing were he put the pelican case....it may or may not work out, but im gonna give it a shot.
jhill15
Today I went from this:
To this:
I'm pretty happy with the results for only having spent $10+free shipping.
Marutuk
KK6WFB
Nice and clear. That reminds me that I do have to clear up the fogginess off my head lights soon as it's needed again. :)
ifixpc
Very nice outcome!
Which product did you use?
I still have some "mothers" (the one that comes with yellow ball for buffing) left from last time. It also does the job very well.
Kallan
