New guy with gen3 montero
ifixpc
Thanks man! I used the 3m kit that attaches to a drill. 3M 39008 Headlight Lens Restoration System https://www.amazon.com/dp/B001AIZ5HY/ref=cm_sw_r_awd_RB2wvb0G7T3VN
I have never used mothers. Does it work well?
Yes, It works very well.
Besides the yellow ball that attaches to a drill, Mother's kit also comes with wet sand patches that work really well on badly hazed lights.
Tried it once, it was a lot of manual work, but results were amazing.
Djbenny
Keep the buffing pad. After a few years you can re-buff with just rubbing compound. Very simple. I always apply wax to my headlights to protect from sun.
jhill15
Nice man, I didn't think about that. Im glad I kept everything.
Djbenny
I've had my pad for 5 years or so. Ha ha. The sand paper pads were tossed. But you can always by 3000 grit and do it by hand with water for other headlights.
nwoods
I used a similar kit from Turtlewax that had the buffing ballhead and the different grades of wetsand paper. My Acura's headlamps were really bad and they came out pretty good. Had to recharge my cordless drill 3 times to finish both headlamps!
Before:
After:
jhill15
Before:
After:
Looks great nwoods!
jhill15
I ordered some of these the other day. I've always seen dakar stickers but never any chrome emblems, so I ordered 4 of em.
they are coming from china, so it will be a week or two before I see em. Hopefully they will be as sweet as they look.
Edit: I found them on ebay...I forgot to mention that.
Djbenny
Jhill15- Nice! Are they for the door handles?
Nwoods- that turned out great!
jhill15
I never thought about that until you pointed it out but they look like they are identical to the chrome on the door handle. The ebay add says they are 99mm's long which is 3.897 inches. That would be pretty sweet if they fit. I will pop those other chrome inserts right out if so lol.
jhill15
I fixed my power antenna yesterday. Super easy and if anyone has a broken mast this will totally help.
Heres the mast I ordered
AntennaMastsRus A084-515821 2001-2006 Mitsubishi Montero Power Antenna Mast https://www.amazon.com/dp/B00JS9QHKG/ref=cm_sw_r_awd_R3Yxvb0TW523S
$40 on amazon.
Tools needed
I had to find a long piece on metal to put inside the broken mast so it wouldn't collapse from the force of the vise grips.
Use a little penetrating oil around the base of the old mast because more than likely it will be stuck on there.
Old mast out
New mast in
It will take 2 people for this, 1 to turn the acc on and off, and 1 to feed the cable into the power antenna motor.
Edit: in order to get the new antenna all the way seated in the post I had to use a rubber mallet to tap it all the way in.
End result
Montero power antenna: http://youtu.be/ICLg-HwbqYc
Djbenny
Nice! I've always wanted mine to work! Ha ha. How do you know if it's the motor or the mast that's broken?
jhill15
If its the motor then you wont hear it when you turn the acc on and off. If its the mast more than likely you still have some of it left inside of the post like I had
I just used a Phillips head to pull the remainder of the mast up so I could grab it with the vise grips.
On a side note, I found the broken mast in the back of my truck just laying in the cargo area shortly after i purchased the rig lol.
Djbenny
Ok. Yeah I don't hear anything when my car goes to Acc. My motor is probably dead. Bummer.
oskarf150
