Overland/cross country vehicle: Lexus RX400h Hybrid
This is a great read so far.
I'm in a similar scenario as you with an LX470 slightly modified and ab to click over 200k. I need a daily driver for my commute 60 mi x 4 days a week. But want to dual.purpose my commuter as a road trip car camping machine.
For the same reasons you describe I'm leaning toward a Toyota hybrid. The appeal.of having AC and heat will really extend the camping season for my 7yo son and I to do more hiking and camping. The RX450h or Rav4 hybrid are on my radar. Initially I was tempted to go with a Prius V but the low ground clearance has me worried... I looked under a prius V and the 5.9 inches of clearance and sensitive parts too easy to bash into a tree branch or rocks. And to a lesser extent the lack of AWD, but my understanding is that toyota hybrid AWD is a bit of a farce relative to Toyotas typical 4wd and honestly it seems that the world of AWD on unibody toyotas seems to be lacking when compared to subarus and, less so, Hondas AWD. And the hybrid RW electric motor even less effective. It just doesn't seem.to be very well executed with the rear electric motor with such limited power and no power sharing differential to limit slippage between the back wheels, sounds like basically an open diff and no trac system to effectively limit wheel spin to redirect the power to the wheel with traction. It's too bad, but still it is likely better than FWD only... sometimes all you need is that little nudge to get the driving wheels onto that bit of grip to pull you through.
I'm not very familiar with the 3.3 or the 3.5 v6 engines. Are they about the same reliability between the two engine series? Any.pointers when looking at the various model years of the RX hybrid? I'm aiming for the most recent and/or lowest miles for $12-15k, ideally toward the low end. I'm hoping I can find one under 100k and 8 years so.it will still.have the hybrid system warranty in case the battery or genset have issues. Hybrids are very new to me, makes and a little nervous not being able.to diagnosed and fix potential.problems without paying someone.
Good luck with build. Keep the reports coming, I think I'll be treading the same.path in the next few weeks.
RE: tires, I recently installed Cooper AT3 XLT 285/75 on my LX. I've really been pleased so far. They've done extremely well in the recent hurricane and stormy downpours, recent snow storm, and general daily commutes. Of course as the tire wears and the softer outter compound gives way to the denser/harder inner layers the tires characteristics will likely change. How else can they put up a 60k mile warranty AND have great attributes... like Blizzak tires that are great snow tires until 50% tread is gone, then you basically have all season tires.
Why 17" rims? I would think 16" rims would alow for more rubber, better to air down when needed, better ride compliance over all for the gravel and dirt?
I love the lx470s, so much you can do with those. You mention that you are considering the rav4 hybrid and rx450h but I would recommend checking out the highlander hybrid as well.
To answer a few of your questions, the 3.3l engine was used in the rx330, rx400h, es330, Toyota sienna, and Toyota highlander/hybrid, and it was the optional engine in the camry for a couple of years. Pretty reliable overall, and the highlander hybrid used it until 2010. The 3.5 which the rx450h is based around has been in use in Toyota vehicles since 2004 (avalon) up through 2018 (still avalon) but was found in rav4, camry, es/rx350, highlander (2011 model year for hybrid), and rx450h (2010 first year). The hybrid variants were tuned down it seems and lost about 20hp, likely for economy. They also use a slightly different engine code based on the 2gr-fe, 2gr-fxe for hybrids. That being said, it's a great engine as you can imagine based on how much Toyota used it.
Regarding the hybrid awd system, as far as I know the rear motor in the rx400h, highlander hybrid, rx450h, and rav4 hybrid are all very similar and all rated at 67hp (95-103 ft lbs) dedicated to the rear wheels. That being said, you cannot lock the rear drive on, it is a system that activates when high load or slip is detected. I honestly don't think the rear tires will ever slip unless on the slickest of surfaces, there just isn't enough power when you factor in the weight of the battery sitting over them as well. It is more of a push to assist the front. You get the extra power from the rear when going wide open throttle as well, say on a highway on ramp, so the additional power is welcome in situations other than ones where 4 wheel traction is the main objective.
The front hybrid motor appears the same or similar for rx based hybrids and highlander hybrids across the years as well. Rx400h and rx450h both use a 165hp front motor (245-247ft lbs).
I'm really liking the cooper's and we will see how they do in the years to come. Haven't had a good enough snow here to test them out (as well as the awd system) but they're great in the rain and surprising how quiet they are. The reason I went 17" was there were a few reports on forums that 16 would not clear the brake calipers. I'm not entirely sure if that's accurate, but I got a good deal on the 17s and was able to get a decent tire that fit.
And for my personal vehicle, with the heat OFF, heated seats ON, nothing else on (car ON obviously), the gas engine runs 8 minutes per hour to recharge the hybrid battery. So with heated seats, and the cars computers maintaining standby, you get 52 minutes before the battery needs to refill (down to 2 bars, up to 6). I think with a sleeping bag on top of the seats folded flat if you are under 5'8" you can sleep this way comfortably and warm, much like a heated blanket (also an option to get a 12v heated blanket). If the heat is on, this will occur more frequently, as the heat is still produced by the engine and goes through a heater core. It is best to run the heat on recirculating so you aren't running cold air through the system. In essence, the heater core is a radiator, so as you run the heat, you are cooling the engine. By running on recirculating, you are reducing how much cold air runs through the heater core, cooling the engine more slowly, reducing the frequency of which the engine must run to maintain the set temperature. The lowest you can set the climate control to is 65 degrees for heat (below 65 is called "LO" which I assume is just outside air temp).
I have not tested the AC time, but the AC is electrically driven, so the gas engine will only need to run when the battery is down to 2 bars to charge up to 6 bars. The frequency will depend on the temperature you set, so if its 90F outside and you set AC to 80F, it won't drain the battery nearly as much as if you set ac to 70F. Though depending where you are, you may not need AC at all at night.
The other nice thing is being able to use and charge electronics if you have an inverter. The 2 15A circuits that power the 12v sockets can supply 360w across 3 sockets, so given inverter efficiency of ~80%, figure 275W comfortably. Enough for a laptop, tablets, phones, tool battery chargers, really depends on your needs.
SORRY for the long post!
I'm another very happy Lexus RX owner. Mine isn't hybrid though. 2010 Lexus RX350 with 217k miles. Its been probably the best most reliable car I have ever owned. My mods are very minor, and are based around my unique needs. But I love seeing a thread dedicated to mild mods for this car. Good luck and keep updating us on how it goes.
Got to try it out for the first time in snow and it did well. It feels like a front wheel drive car in general. I didn't get into anything deep enough to induce much wheel spin unfortunately, hopefully we get some more snow before spring! I also got to take it on an unpaved road in the state park and it felt good to get off the tarmac for a bit. Handled that well. I'm looking into some minor mods, like the fog light mod to allow fog lights to be on without headlights, and I want to hardwire my inverter to be on a dedicated circuit with a switch, more to come on that. Actually, what is the best way to wire an inverter, assuming bare wires on both ends? Solder and heat shrink, then tape? Let me know what you've done. ?P_20190220_142646_vHDR_On.jpgP_20190220_144229_vHDR_On.jpgP_20190220_144010_vHDR_On.jpg
Looking forward to hearing about your upgrades - In the same boat with a 2008 that I bought in Milwaukee, WI back in December. We have had a record snowfall this year and this beast has done an amazing job of pushing its weight around in the deep snow. Only real issues were slow technical moves where a dedicated 4X4 drive would have had better traction. Easily getting 25 MPG over the course of a couple tanks while just trying to coast as much as possible.
awesome! I notice the vehicle isn't as eager to toss it's weight around like a 4x4 but I haven't put it in a situation where that is an issue. I am getting 23MPG steady for highway driving this winter, but get about 27MPG city in warmer weather. I was getting about 1MPG better before the tire upgrade though.
Besides the extra power, the nice thing about the 3.5 is that it's a timing chain instead of the belt found on the 3.3. With a couple of oil line upgrades (VVTi line and oil cooler hoses), the 3.5 is very reliable and maintenance free (other than oil and filter changes).
-Mike
-Mike
Didn't know the 3.5 went to a timing chain, that's definitely a nice thing, especially when looking at used cars without access to service history.
Last week I packed the RX and headed to Vermont. Was a great trip! Loved the roads in VT. Long and unoccupied, fast and curvy. But the high speed turns and the unpaved rutted out sections got me thinking about suspension. There is definitely some lean through the turns that make me uneasy, which can be expected with nearly 150k miles of driving on the struts. Also, I heard a little bit of contact with some underside bits going through some muddy detours. I would like to freshen the suspension and if possible, gain a small lift in the process. I assume new OEM struts would probably give me 0.5-1" of lift compared to how it sits now anyway, but I am looking at struts from other vehicles in hopes I can get something to bolt in and give another inch of lift on top of that. The RX shares a platform with the Toyota highlander, so I am looking at struts from 08-13 highlanders and doing a bit of homework on those. I believe for the front I have no choice but to run a spacer, since the front struts between the two vehicles seem very similar already, but the rears seem to be just a bit longer for the highlander. More to come!
Do you have any plans for front recovery points? With our Sienna, since it has absolutely nowhere to attach a pull strap at the front (not even tie down loops), I am considering adding a tow bar attachment to the front (like what would be used to tow it behind a motorhome). Not ideal, but at least it's designed to handle the weight of the vehicle. I have no idea what front points are available on the RX.
-Mike
-Mike
What year sienna? For the RX it has a tow bolt/eye bolt that screws into the front bumper. You can see 2 squares inside the fog lights where the bolt goes, but it is kept with the hitch otherwise. I bought another bolt so if needed I can hook up 2 recovery points up front.
That sounds like a good setup for the vehicle and use type. If you ever need them, I would use both at the same time if at all possible to distribute the forces as best you can.
My Sienna is a 2007 and doesn't have any provision for front recovery. Even my VWs (GTI, Jetta) have one place on front bumper for removable tow eye as you described. I have a shackle like your's for the Sienna's hitch for rear recovery.
-Mike
-Mike
that's a shame toyota didn't include front recovery for you. I would guess there is something to hook onto underneath then?
Not really. Just control arms or whatever you can find, I guess. I'm scared to know how the tow trucks do it.
-Mike
-Mike
Probably from where they shouldn't.
I'm grateful for all the storage this thing has. I loaded it for my trip to vermont, but I think I am going to leave it stocked like this full time. Nothing in there is too heavy to worry about. Better safe than sorry.
Power inverter held in place with double sided tape (the 3M extreme outdoor stuff):
512486
Here is the factory hitch compartment, with a set of winter gloves, a snow brush, battery powered light, water, a tarp, and some tin foil:
512487
Here is the main storage compartment which includes tow strap, tow hitch, bungie cords, air compressor, pair of spare shoes, a couple first aid kits, more winter gear, portable jump starter, snow/sand tracks, a spare inverter, and some other stuff that fit:
512488
Still a work in progress, always. Threw the stock wheels back on for fuel economy on my trip to Vermont, but I don't think it made much difference, so I will probably put the AT3 4S's back on full time.
512489
MOLLYmaz
