Thanks for the kind words.
I'm working on getting some driveline vibrations sorted out and a few maintenance items this week. Hoping to make the trip across the USA in mid December from Montana to Vermont and back. So I'd like to make sure everything is as good as can be before I set out on a 9000 kms road trip.
I'm still undecided on what I want to do with wheels and tires. I might put it off for a little while.
When you get to NY, shot me a PM. Would be cool to get to share stories from both sides of the continent. Im originally from BC, and hoping to get back out there one day...:coffeedrink:
that sounds like fun. i recently did a trip from Florida to Washington state and back, but not with my Jeep. hope to one day afford to take it on a long trip.
About an hour north of Albany, about the same away from Rutland Vt. If you do end up close by, from me a pm...I've talked to a couple of people from Vt, and New Hampshire, gonna be doing some overland adventures over the next year...
What part of NY are you in? I wouldn't mind taking time off driving to hang out a bit.
That would be a fun trip. How long did you take?
Need some opinions on wheel and tire setup. I'm looking to go with a wider stance. Here are the options I'm considering:
1.Adding Spidertrax 1.25 inch wheel spacers all the way around. Keeping stock wheels and the 32 inch General I've got on there.
2.Getting 17 inch wheels with a better offset. I had AEV Savegre in mind but after reading from various places about people having wheels cracking or breaking on them with no warranty I'm a bit worried about them holding up. The cost is fairly high and I'm not sure how bad the issues are on the scale of how many wheels are sold.
3.Getting 16 inch wheel with a better offset. This size is hard to come by in a 5x5 bolt pattern for some reason, maybe I'm just picky on the styles I like but I find most wheels tasteless apart from maybe the Fuel Anza D558 : http://www.fueloffroad.com/wheel.cfm?id=4047 Not sure what the offset would be like on the WJ? At this point I'd get new tires as well. 16 inch tires seem to be about $50 cheaper each than their 17 inch equivalent.
4.16 inch JK steel wheels. I have a set of 8 sitting in the basement. I'd have to run them with spacers. They're cheap, disposable and I got them for free. Not the best looking wheels but they might do the trick for a cheap setup. Again, I would get some new tires at the same time.
Looking to see what you guys have for experience and opinions. I'm always a bit wary about wheel spacers since it's an extra part that gets added to the mix. Had a set on my 4Runner and I always felt like they were "flexing" under load...most likely just in my head.
What snorkel is that. I like
I'm a little late to the party here but I would personally go with Spidertrax spacers. You have a nice set of wheels there and if you stick to the torque specs on the Spidertrax wheel spacers you should not have any problem. I have many hard miles on mine and they are performing flawlessly. I do not know they are there.
