Pi, EGT, AFR, Boost, Temp - Digital dash build
Interesting. I tried the link in your sig, but its not working since the server upgrade. Does your NPR use OBD2? Or have you connected your sensors individually to the dash?
The local shop that stocks these, also stocks a similar unit from PowerTune, which is an Australian equivalent device. The Holley unit is worth almost $4k here including delivery from the US. The PowerTune unit is between $1k and $2k depending on options.
No my NPR is swapped over to a 12v cummins so it has no ecu. The sensors are all individual aftermarket sensors that are pretty common. I understand the price issue in Australia. That's too bad. Adding additional sensors is an option too. Leave the OBD2 stuff alone and add sensors to feed your dash.
2eleven
