Pretty Ugly... 1835, The Build Begins
Well after a heap more lifts and some extra steel 75x50x6mm for the longnitudal frames ( to stop the east west flex while it is leant over) we have ended up finding the nutral point of the chassis . We picked up the rear right wheel to 700mm and pulled out the center pivot pin once tipped and then replaced it then the rear pivot pin and then replaced it once we had concluded that pulling the pins made no change to the hole alignment
The observant of u will notice the 100mm pipe in the frame this was just to stop the weight of the frame from pulling the rear end down when pivot was removed but it did freely roll left and right so if there was pressure there it wohld just roll.( i could roll it either way with my little fingure .
Fantastic work.
To me the only reason for NOT having a pivot in the front ( not well possible with the tranny in the way anyhow) is that the box can sit lower without interfering with the rear wheel while the frame is twisting. So hence often people make the center or the rear the solid point.
That, pivot front..solid middle..pivot rear, is how my 404 is designed.
Nevertheless I will modify that in the same setup that you have. Solid front..pivot middle...pivot rear. Then I can make a hard connection to the front cab and essential enlarge my living space and stay with a smaller vehicle.
I agree that it seems to be logical that the pivot line in the chassis is in the vertical center between the top and bottom frame rail C beam flange.
But in the unimog 404 it is designed at a much higher vertical position then that.
With that in mind and assuming that Mercedes has done many test and calculations..maybe the pivot is NOT always in the vertical center of the frame rails and maybe even changes depending on the load.
From a complete tension free twist standpoint . Your front hard connection should be theoretical on two individual pivots. On in the vertical center of each frame rail. That might not practical or over complicated but it will help with the east west movement while the frame is twisting for a miniscule amount.
I can not see in your pictures if you have similar rows of holes in the plates that are welded / attached to the frame rails.
Anyhow, great work. Hope to see more pictures.
Johan
Hey Johan thanks for the feedback and comments i will post a pic of the front fixed connection for you. But with how the exhast and airbox and fuel tank are going to be i cannot put the fixed point on the center of the chassis but on the top edge of it using oversize steel plate etc.
For the tests i did i welded the angle horizontal bars to a 100x50 spacer and simply clamped this spacer to the top of the chassis. I am now wondering if i should make a moc front fixed pivot and double che k that it does not alter any of the rear pivot points. I sure hope it doesnt lol.
It looks like your cab is not twisted with your subframe that much. Does your can has two connection at the front of the frame rails and one pivot in the rear? In that case the twist that I see is over the frame rails length from the hard connected frame rails to the cab tilting mounts in front.
Is that length and twist conforming to the twist per length you deduced earlier?
what are the vertical dimension of your pivots now relative to the top of the frame rails?
johan
Hi Johan the cab had very little twist/angle compaired to the frame. It is fixed to the chassis in 4 points 2 ruberised bushes with aprings at front which it hinges on when u tip the cab and two sprung locking attachment points at the rear.
The pivot points om my chassis are
Rear = 93 mm from bottom /nearest the ground edge .
Middle = 184mm from bottom
There is a 100mm space between the top edge of chassis and the bottom edge of subframe.
Subframe size is waiting on engineer to give me final calculated size but originally was 150x100x9mm by 5500 long plus the 150x150x9mm out riggers to mount container . This was to enable it to take the full weight of a loaded 20 foot contIner incase i or anyone els decided it would be a good idea to use it comercially. I have since changed this so the truck will be registered as a rv /campavan and not commercial.
Interesting, so the pivot axis runs under an angle thru the frame rails.. that is as in not parallel.
Are you going to repeat your test with a load on the subframe and see if it changes?
Also how do you feel about the localized stress on the frame rails when the subframe and camper pivot from left to right and visa versa?
Johan
Hey yes you are correct that it does not run parellel to the chassis but at an angle.
The way i plan to mount the pivots will spread the loading out somewhat but not the same as an intermediat frame over the chassis but under the subframe.
Yes i do plan to repeat the tests with weight but before i can do that i need to tack up the final subframe and use the pivot points i have at the moment as a more acurate starting point to rerun the test.
I might add to the above comment that the attachment points and the truck chassis have been checked by land transport engineer and oked for the full load capacity of the truck. Which it will never carry as an expedition vehicle
I have found and ordered up the Merc ultra bushes for the middle and rear and the fixed elastomered bearings for the front that uses a 100 OD attachment point. But as i was worrided the center point where i can attach tgis to the front would mess with the test results i already have i decided to make up some test ones out of 100 and 115 od pipe with a good old peice of rubber in the middle
Then mounted these onto some scrap plate and bolted it to chassis
After this i reran the lift tests and removed middle and rear pins neither of which were under any torsional load when rear was lifted over 700 odf the ground with a nice flat mic frame as well
The outer 25mmx25mm shs is bent down after the front cross beam but that is not to do with the torsion/ its just bent lol.
The good thing about having rubber in the front fixed bearings is that when twisting the chassis i can see if there is any compression or twist in the front attachment points ( before spot welding to subframe i could twist this and compress/pinch the rubber inbetween the 2 pipes)
Any how i was pretty happy to see minimal pinching if any and this is 3mm of rubber the actual one has nealy 10mm i think.
I have lots more to report just out of time to post
Stay safe
Been getting a little work done on the sub frame
Have also recieved a package from Belgium
2 lots of the mb ultra bushes for the rear pivots and the 100mm front fixed point bearings 20210728_100111.jpg
Stay safe
I like to your center of frame mount . Looks great.
Johan
MOLLYmaz
