Progression of a NEW Photographer (At least I hope to be)
Yeah, I have recently changed my camera to only shoot raw and use the second card as an overflow.
Robert, do you do any Sharpening in post?
I use Adobe Camera Raw for my sharpening: http://www.youtube.com/watch?v=_Pg7rAAy064
and sometimes a bit more in Photoshop once I've resized an image for web use: http://www.youtube.com/watch?v=HI3FC18Ufj8
So far the only post process stuff I have done is my attempt at the HDR pic. I know that the nikon SW that came with my camera (that is what I use to convert to jpeg) does have the option to do some post processing, I just havent learned or played with it yet. I also just got lightroom and adobe, just need to learn how to use those too.
I agree with Chris about doing as much in camera as possible, I'm a grumpy old photographer who goes back to that anachronistic form of photography that used film (gasp). :) Back then we often baked in a look and tried to perfect the shot in camera, using lenses, filters, and a variety of tricks. But. No matter how much we tried to lock it in in-camera there were loads of pre-, peri- and post-processing tricks that were used to give the image a certain look. My point? Always try and get it right the first time, but don't be afraid to play with the image in 'post'. I say this because when you shoot RAW you must play with the image in post and you shouldn't feel less of photographer for using Light Room or Photoshop etc.
(there are plenty of discussions on LR v PS in these pages, have a look through them but in essence most of us who use PS have used it since before LR came about, and are comfortable with it so don't want to change. LR is probably the best way for you to go, and forget about PS.)
Something that helped me understand digital photography is reading a lot of the Adobe and camera manufacturer information on RAW v JPEG. When you shoot JPEG you are effectively processing the image in camera - the camera applies a series of settings on your behalf around colour saturation, sharpening etc. and the result is a JPG file which is 'baked in' and (relatively) harder to alter. On some cameras you can adjust the amount of processing JPEG is doing, but it is still doing processing. RAW is pure sensor data (within technical restrictions) so none of these tweaks have been applied. They are left up to you with the expectation that you want to change settings after the event. The image that you see when you first open a RAW file is interpreted and usually very flat and 'soft', regardless of the camera manufacturer you use. Therefore to get the best image when shooting RAW you have to go into your image editor and sharpen/tweak/colourise etc.
My view of the New World Order in photography is that 'real photographers' know how to get it 'right' in the camera with composition and technique, and then know how to get the most out of the sensor data in the editor and then bring the image to life when turning it into a JPEG (or other image format), otherwise they get half a result.
One thing I'd add to the comments about your photos is you might want to read up on White Balance. It is very important in digital photography and can help restore a more natural look to odd colour casts. I tend to look at it when I want to affect the emotion of an image - warmer and more comforting or bluer/whiter for a more natural (or pushed, clinical) feel.
Cheers,
Humphrey.
Another thing I meant to add - depending on the image editor you use, when shooting RAW the autofocus points are stored so that you can actually go back in and see which point or zone was used in a particular image. I agree with Kevin that the focus point in the stump picture seems to be on the bush rather than the stump.
This can be useful in certain circumstances. I still tend to use the central AF point to meter from and set AF and then hold the button down halfway whilst I recompose/reframe the scene. I do this habitually and it helps in always knowing where the focus and metering are set when using AF. But as I said I'm old and get a bit confuzzled by 64 gazillion AF points operating in a zone.
Humphrey.
ELShockley
