Qbombs 17 Taco and M416 Build Thread
I have some vibes so I got under the truck and measured my driveline angles, ordered some 3* shims from @HeadStrong Off-Road and I think that will get me where I need to be. I will update after theyre installed. Its a vibe below 30mph, you can feel it in the floor board mostly, can tell its coming from the back or at least I feel like it is. I did the needle bearing ECGS bushing so its not that, the next logical thing is driveline angles since my rear is so high without weight. I found a thread on here (https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/) and used it to measure driveline angles, my pinion angle is 3* higher than the 1st shaft angle so I ordered a 3* shim.
ELShockley
