PetitFrereArmada
Those are some great pics.
Do you have any pics of the new setup?
Brett C.
IronworksTactical.com - owner
With the right shocks. You can right them that close to the center. Shocks don't travel much when that close together so a stiffer shock is needed
Because there is more leverage with them placed in bound correct. How would you know how stiff you'd need to go? Trial and error?
IMG_7764.jpg by Monte Nickles Photos, on Flickri did a setup like that to a buddy's truck. Set them up so they angled a tad though and mounting locations are different. He loves it.
on Flickr
Yes trail and error unless you find someone that has done it. I can ask someone that has done it. He said with the correct shocks it worked great
If it's just a trail rig than it doesn't really matter much.
I have no stability issues with them mounted further inboard. The ride is great and this not just a trail rig. I put 300+ miles on this truck a week as a daily driver. Also not running a front sway bar. Truck still feels nice and solid. It makes no sense that a stiffer shock is needed with them mounted further inboard. If it was a single shock mounted dead center on the axle, then maybe. It's not a race car doing high speed cornering. The amount of travel the shock has has very little to do with the dampening provided. On the road and fire roads you are not worried about lots of axle movement and don't need tons of travel out of the shock and the dampening is not different than if they were in the factory location. A shock mounted further outboard provides stability benefits when cornering and I probably have a slight loss there but it's not anything I have even noticed and I've been known to rally the truck pretty hard. The only time you're worried about needing lots of travel from the shock is typically in the rocks or where lots of articulation is needed. Those conditions usually are at very slow speeds where the quick dampening isn't a factor. You guys are making this way more complicated than it needs to be and over thinking it.
Factory placement of shocks on a lot of Domestic full sized trucks and SUVs are well inboard of the leaves and seem to handle those loads just fine. 3/4 and 1 tons, look at them the next time they are in front of you on the highway.
You can do it without needing longer shocks. I didn't change the shocks I had. In the stock locations they were too short, but by changing the mounting locations and angle of the mounting I am able to run the same shocks.
