skid plates?
TEETS
I am going to make some skid plates for the front of my truck and the gas tank. I was wondering what steel do you guys use to make them? thanks
3/16 thk AR X10 (Abrasion Resistant Exten-50,000lb yield). X10 provides a rust seal coating that prevents further deterioration after the initial rust is formed. This is the same chemical and strength spec material used in ISO containers used for shipping "stuff" overseas.
Sidebar-common A36 COMM or 1010/1018 is 36,000 lb yield steel. X10 is the high strength version.
Best as always,
Bob Sheaves
CEO
catNET Incorporated
http://www.catnetsolutions.com
Don't forget that there are other options....
Some of the new plastics work pretty well like UHMWPE and others. They have been using this stuff on rally cars for years. It takes a lot of punishment if designed correctly. Its also pretty slippery and the overall weight is pretty low.
Then there is aluminum. This can also be used to make some killer skidplates that are not nearly as heavy.
I think far too many people use too heavy a material for most skidplates. If designed and built properly I rarely see the need to use anything more than 1/8" steel. Build smarter not just with bulk. Keeping your vehicle light is going to buy you a good margin of performance on and off road as well as with mileage.
Are there factory shields that would work?
My truck had no option for shielding. I was able to use shields from other models and years to outfit my truck with .250 formed aluminum alloy steering, front differential and transfercase shields. The fuel tank shield is .120 steel and came off of a first gen. Some of the braces had to be modified to fit with a fully boxed frame.
I have less than $50 invested in all the shields, including hardware.
Salvage yards do not always inventory shields. They can be picked up pretty cheap. Around here they go for $5-$15 each.
A little time scrounging can be time very well spent. I don't know if this is an option in your case, but it may be something to think about.
Please see inline comments:
There is no impact resistant plastic capable of withstanding 21G penetration loads. Not at any price.
Aluminum is not as strong as steel. The strength of materials is governed by the modulus of elasticity of the material being evaluated. Aluminum has 1/3 the strength of steel in the same thickness. The weight of aluminum is also 1/3 that of steel, for that same given thickness. To get the same strength in the materials, you need 3X the amount of aluminum to get the same strength of steel, at 1.75x the price per pound of steel. Basic engineering practice.
"Build smarter" also means to determine the loading and forces on the vehicle BEFORE selecting materials and making determinations.
Best regards,
Bob Sheaves
CEO
catNET Incorporated.
Did some one say skid plates?
Aaron
Cool Aaron I am looking to do something like what you have I like them. I do not think they have the front option skid for my truck but I am going to look for one for the gas tank. Thanks for the replys
Bud Built skids.
I'll second the Bud Built skid plates. Very heavy, but worth the protection is worth peace of mind. Additionally, there is something to be said about a quality product. My skids bolted right up with no issues (OK, one nut was hard to put on due to the clearance between the existing cross membere and catalytic converter being tight).
Front skid = 55 lbs
Belly pan = 50 lbs
Cross member = 15 lbs
There is another thread about the Bud Built Skid Plates.
Cheers,
P
Front skid = 55 lbs
Belly pan = 50 lbs
Cheers,
P
But this is for a Dodge Ram... I do not think Bud makes any plates for Ram's
Do not underestimate the importance of light weight....please.
I still feel that more exotic materials can be used very effectively. If they couldn't you wouldn't see them in places like the Dakar rally, baja, about every WRC race, aluminum jet boats, fishing boats, competition level rock crawling, and many other applications.
Yes I know but I was trying to give perspective if he wanted to build his own. AL might be that way to go depending on what you want it to do. Its always about what you want it to do.
Aaron
Yeah but 4 out of 6 of what you mentioned get replaced after the event anyway, bend it beat it swap it repeat. I don't imagine those guys run the same AL protection over and over. Though I do agree there has to be something else. AL would be my second choice If I could get the image out of my head of the 4runner being hi centered. Though if just light armor is what your after AL but if you have to be able to resist small arms fire and rocks, steal may be the only price conscious way albeit not that light weight it will leave your wallet heavier.
Aaron
Fj89
