Spare fuel swing down
IMO, I don't think it would really matter whether the cans were metal or plastic. If a rock or other object were to hit either type of can to cause a puncture, it would likely puncture either can. However, if it's just a dent, the plastic would at least return to its original shape instead of having permanent dent like a metal can would.
I would go with plastic if I were doing this. Leakage is still a possible concern.
Cool idea though.
Howdy. Thanks for all the great comments.
I have been using the above set up for a couple years and it works VERY well. I no longer use the strap to hold the cans in place. They don't move enough to warrant it.
I have never had a leak at the cap with these cans. I do check frequently when using them. I also use a strap wrench to tighten them up and make sure your gaskets are good.
I also make sure that these are the first two cans I use. So they get emptied fairly quickly into a trip (usually the first 3 days) At 1/2 tank, both go in.
highly recommended.
i also fixed all the links to my build here on expo.
I will be adapting the idea to utilize my stock spare tire carrier. I will make a basket that will fit securely up against the tire stabilizer pads in the stock location. Stow the gas cans in the basket, crank them up into the tire carrier area, then down the road I go. This would be especially convenient for me as my truck weighs a ton and I don't want to carry any more weight then I have to every day. Border crossings would be less stressful with the ease of displaying the cans, instead of explaining an aux tank.
Great idea! Beautifully simple. Use internationally approved fuel containers!
Wolfbox
