Stud spacing??????? Help Please
Ramdough
Anyone know the stud spacing on an 02 tacoma?
6 studs x a number right? is that number stud to stud distance in mm or the circle containing 6 studs?
What is the number?
Thanks, construction starts tomorrow.
Correct
What is the number?
I believe that the stud spacing for Tacomas is 6 studs on a 5.5" diameter circle.
Will you be constructing the bumper? Post some pics of the progress. :jump:
Cheers :beer:,
P
What is the number?
The 4WD Tacoma is 6 lug on 139.7mm (5.5") PCD, 2WD is 5 lug on 114.3mm (4.5") PCD. The stud size is 12mm x 1.5 and 4WD center bore size is 108mm, something like 4.25". I think the stock offset for IFS trucks is +15mm, so backspace should be 104mm on 7" rims, right?
empireoverlandza
