Stumptaco's has gone over to the darkside..XJ style.
What kind of glove Bill? I didnt see this until I was getting ready to do an update. I havent seen any randomly sized gloves though....what do they look like?
Time for an update....a picture story, if you will.
So since the last picture I have:
Gone Camping
Trimmed another set of XJ Fenders
Built and installed a roll bar in my Father-in-laws little fun car, the Miata. (In Japanese, Miata means - "only midgets can drive this")
Played Daddy daycare several times due to a semi-sick kid over the last couple weeks...
Fabbed up a receiver hitch on the back of Yeti_in_GA's (Steve) offroad popup camper, and modified a ammo can for his swing out gate.
And now finally what you have clicked on this link to see, some progress on the Teal **********.
Got some more tube done on the outside.
Got the majority of the B-pillar tacked in.
Car seat still fits in a rearward or forward facing direction!
I figured I would work my way around the Jeep and do it all in sections. Finishing the welds, cleaning anything up, adding gussets etc. I am also trying to paint each section as I go. Started with the front passenger side.
Some appropriately placed grip tape, cant tell you how many times I have had to crawl out of or on top of a vehicle to get to something, especially when winching out of deep holes/mud.
Got my GPS Receiver mounted.
Started tying in the exo cage to the unibody. Speedholes for style points.
This basically is a finished (fully welded, and painted) passenger side. Note the extra tube/guessets on the rear section, as well as the D-pillar unibody tie-in.
Instead of going on around the outside of the Jeep, I decided to stop in the middle and do the internal C-pillar tube, and rearward diagonals.
Stripped everything out of the back of the Jeep.
Got the two vertical pieces of tubing in, these go through the roof an tie into the exo cage halo. They are also welded to the body via 11gauge reinforcement plates to spread the amount of force put on the thin sheet metal in a roll over.
More tube going in....
Follows the contour of the rear seat.
So this brings me to today...
I decided to go ahead and mount my fire extinguisher and CO2 bottle on the rear diagonals so they are nice and secure. No point in building a roll cage to protect you and your family only to have a 40 pound bottle hit you in the back of the head during a crash and kill you.
Here is the Fire Extinguisher mount.
Now...some of you may remember me building this CO2 mount a while back? I decided to just modify it instead of building something new. Just had to cut the back off of it, and notch it to make it fit around the tubing.
This is how it used to look/mount.
Thats it for now. More to come, this week should yield some pretty progress on the Teal B*itch.
That's a great looking roll bar & definitely should give your Pa-n-Law great roll over protection (which he will hopefully never need)!
Nice, Stump.
We have to go get it dirty. The top part of Sheep Wallow was sorta completely washed out the last time I was there; you'll be able to rub your left side entirely against the bank asn you scale your way out of the hole. The PW almost tipped sideways in it. If I didn't have the swaybar disconnected, I think I would've quempled the fenders at least.
Maybe the glove-swapper was Mike... Mine were tan elkskin gloves lined with some sort of fleesy stuff. The substitute glove is deer, I think, and smaller.
Yep, definitely havent seen anything like those, I know the ones you are talking about. Still got a fair amount of work to do, but itll be ready in a couple weeks. Sheep wallow sounds fun now...
My little boy has that same dog and stand up toy and bouncer.
One question: How do you take an ammo can apart to paint it nicely? I've got a couple old ugly ones that I'd like to farkle up but I can't figure out how to do it so it looks professional. Getting underneath the latch and the handle is my problem, do you just paint over them then tip them on the side so they hang out and paint the parts you missed?
That dog is creepy, and annoying. It just starts talking for no reason... it has scared the crap out of my many times!
The ammo can was kind of a pain, I basically just painted the outside. I did it basically like you said, hung it up, and then flipped it over after it dried and did the other side. The latch I just did one side, then raised it up, and did the underside. The only reason I painted is because I raw steel on it after welding on the mounts, and lock clasp behind the latch.
Got the back end of this thing done...
Found some decent carpet at the local Pull-A-Part, cleaned up pretty good for a 19 year old piece of carpet!
Also redid my old battery area, and gained a LOT more space. This is what it used to look like:
This is what I did to it today. Just made a steel panel that covers everything, and mounted the inverter and 12v plugs on the interior panel (which I also got from PAP today)
Forgot to take a picture of the battery area without the cover on...(Yes, its vented.)
Here she is, all done! Got the carpet in there after painting the bars and floor.
My boy has this one barn yard toy and one of the things it says is "I'm a pig. Oink oink. I like mud!" but every time I hear that I swear it says "I LIKE BLOOD".
tbnd88
