Switcheroo - 1 Bored Clerk's 2013 Tacoma Build
Got some work done today!
Did the tailpipe-ectomy
Dropped in the new 3rd member and added my modified E-Locker guard. I trimmed the front corner of the guard off to be sure that it cleared the tank. I covered that mod earlier in this thread.
Got my new BFG KM2s mounted and changed my transfer case oil.
In process photo with way too many tires. Especially since we only have one damn truck!
Tomorrow morning? SPC UCAs!
I posted this in a thread I just started in the North America Trip Planning section but it may get more traffic here??:
My wife and I are going to run/attempt to run The Rubicon Aug 24-26. It will be our first time there and the hardest trail we've done. We're usually up for solo trips but I figured I'd open this up to other folks who may be interested. We are NOT going to The Rubicon to blaze through it and run the hardest lines possible. We ARE going for the amazing scenery and camping and to see the various obstacles that I've read so much about over the years. I grew up around Lake Tahoe and love the granite, dust and trees of the Sierra Nevada. We are also completely open to turning around if we feel like we're in over our heads or are stressing out more than having fun. I'd rather go check out other trails/camping than stress myself or my wife out trying to run a trail above our capabilities. We are both conservative, good-natured, level-headed and not awful at problem solving. I'm also fairly handy with wrenches. We will be as fully self sufficient as if we were going alone (after all, we are willing to go alone). And, yes, we understand the benefit/safety of multi-rig trips anywhere remote. But we are also willing to venture out on our own if we feel comfortable doing so.
I would like to find some similar minded folks (1-2 rigs would be perfect, I think) who may want to go with us. Someone with recent experience on that trail would be great but not a necessity.
Please feel free to post up any other trip planning details that you may want to share.
I realize this is crazy short notice but I figured I'd put it out there. Thanks.
The truck is in for an alignment right now. Hopefully the shop understood what I wanted and will take care not to stretch the ABS wires! The plan is to use the LCA adjustments to push the lower ball joint as far forward as possible (gain clearance between the tire and the back of the wheel well) then use the SPC UCA to set the caster and camber. Should be easy! We'll see.
I have a lot of updates to do...I've been busy! I'm going to start with an easy one: extra bed tie down loops!!
First you need to buy these from Toyota (or find something similar). What is pictured here is designed to be mounted to the sidewall of the bed. There are instructions on where to put it that come with the D-ring. FYI.
Then take out your bed bolts. You need a t-55 torx drive. My bolts came out with a nice SCREECH!
Then you'll need to remove the captive washer on the bed bolt. I've read of folks using a dremel but I chose to use a file. These bolts are super soft and took all of about 3 minutes to file both of them.
Then you take apart the setup you got from Toyota to liberate the D-ring. Slide that over the bed bolt then put the bed bolt washer back on.
I used some never seize on the bolts because it seems their only purpose in life is to seize. Don't let it happen to you!
Now put the bolt back where you found it and tighten it down! Seriously, it's that easy. I will mention the the head of the bed bolt has some slight interference with the D-ring. No one mentioned that in the threads I read. So I'm mentioning it. I decided it was no biggie.
Now, you can do whatever you want here. You can cut a hole in your bed mat or cut a slice and let the ring poke through. That's what I did and it holds the ring up for you for easy use.
Seems to work pretty well considering it's not made to work with that bolt. The ring cannot rotate around like the ones in the back corner. FYI. I just oriented them how I knew I was going to use them and they appear to be working really well.
I finally got my skid plates back on the truck! It's been a while. I had a shop cut the exhaust crossover bump off and weld in a flat plate. Then I cut a second notch for the new exhaust.
Everything seems to fit really well and installing the plates is so much easier without that stupid exhaust crossover pipe under the transfer case. Life appears good but I'll give a trail report on if when we get back from our trip next week. I'm really excited for the flat belly!
Looks good! I had to cancel my exhaust appointment last minute, my daughter was throwing fits and I had nowhere to take her. Couldn't see driving all the way up there and trying to keep her there for a couple hours.
Hopefully I can do it in 2-3 weeks.
What is the rear of the skid bolted to? Is that a tab coming off of the sliders?
Probably a good call with the kid situation!
Yeah, I modified the rear mounts of the skid. Originally, there was a tab that sat on the bottom of the frame rail and you were supposed to drill the frame and bolt it up. I wasn't a fan so I made some new brackets and welded one to my sliders and one to the skid plate. Now they bolt together and the bolt heads are tucked nicely out of harms way (mostly)
Looking good! You guys still planning to run the Rubicon next week? If so I'll be curious to hear your thoughts, everything I read makes it out to be a very burly trail.
Yep. We leave tomorrow morning or our drive down. We're planning to go have fun. If stuff gets stressful or not fun on the rubicon, we'll turn around and go do some other exploring around. No biggie.
I've got a lot of catching up to do here! The first 1/4 mile of the rubicon was great but we didn't end up running past gatekeeper. Ill explain more when I get all of my other updates done: new rear suspension and LRA fuel tank!
Rear suspension v2.0! I finally decided to step up to a full leaf pack on the truck. The wheeler's three leaf HD add-a-leaf worked very well for most things but it had a few shortcomings. Mostly, sophistication. It held some weight, rode fine, and was generally quiet. But it also stacked up really bad...meaning that it was soft, soft, soft, then BAM!, extremely firm. I also found that once it hit that extremely firm zone, when loaded with a lot of weight, it took nothing to blow through the rest of the travel and smash to the bump stops.
For replacement, I ordered the following:
All-Pro expo springs
U-Bolt flip
Timbren bump stops
Fox bargain basement shocks (recommended by All-Pro as appropriate travel for the springs)
Stainless steel extended rear brake lines
After a several months long, and very frustrating process, All-Pro finally delivered all the goods. I didn't do some crazy write up because it's been done well already. Just check out TacoDoc's install and you'll get it.
So, on to some pics and notes!
Install the rear brake lines first. It's easy. Accessing the rear drum brake bleeders is a bit of a pain. The bleeder is in an odd, sunken location which makes it hard to get a wrench on. I ended up cutting my flare wrench to fit better. It worked fine. However, the wrench pictured below is way more awesome for the job!
AutoZone. I'm sure much cooler ones exist but this one works great.
As far as bleeding the rear brakes, it's really simple on VSC equipped tricks. Turn the ignition key to 'ON' (don't start the truck!), hold the brake pedal, open the bleeder valve and the ABS pump does the rest. It'll pump the fluid for you. Make sure to NOT allow your reservoir to run low. Air in the master cylinder means a trip to the dealer from what erase arch I could find said. Close the bleeder, let off the brake and you're done. You may have to fill the reservoir and repeat depending on your situation but it's so easy.
On to the springs. This is how they show up
A hateful amount of stickerage.
Nothing a little 3M adhesive remover, a plastic scraper and a knife can't fix! Took about 15 minutes per pack.
Then, paint! You'll want to paint. They come completely beat up because they weigh about 70lbs each.
Follow TacoDoc's report and you'll end up here...with a few added notes.
1. I used a lot of BelRay waterproof grease on the bushings. Inside, outside, make sure all the grooves in the bushings are greased. Don't be shy with the grease!
2. Install the Timbrens on their mounts and onto the spring plates before you put the u-bolts in. If you don't, nothing fits together! If you install the timbrens on the u-bolt flip plates first, the washers for the u-bolts will push up against the edge of the timbren mount and locate nicely. If you do up the u-bolts first, they'll likely slide in the slotted holes in the u-bolt plate and not leave enough room for the timbren mounts. Ask me how I know! Frustrating. Doing it the way I recommend will require that you get a crows foot for your torque wrench to properly torque everything.
3. The Fox shocks come with the wrong lower mount bushings installed. They are much too wide to fit in the lower mount on the axle and there is no sleeve for the bolt. However, the correct bushings and sleeve come in the box with the shocks. I used two sockets of appropriate size along with a clamp and swapped them with little more than a balancing act trying to keep everything aligned while I clamped it all together.
I have a question for those of you running this setup: the way the timbrens are mounted, they fill up with crap and water...and can't drain. Any issues with that? Anyone else care?
In general, the kit is pretty good. The notes I posted would have been good to know at the beginning. The main gripe during install is that the general layout of the timbren/mount/u-bolt flip plate is a little lazy. Much of the issues I had on installation could have been eased with a very slight couple of design tweaks in the timbren mount.
The second, and ongoing, HUGELY ANNOYING gripe is that my set (and two others that I have heard about) creak so bad! They creak when you turn, when you stop, when you go over a bump, when you accelerate, when you look at them too much, when you don't look at them enough, they are ALWAYS creaking!! I've read about one guy discovering that the creak comes from the area where the springs touch mid span between the center bolt and the slider pad at the end of each leaf. He had to loosen up his pack, glue hard rubber under each leaf at that location then grease the rubber interface to the leaf below. That sounds like a super sucky job that I'm none too excited to get into. Any other folks out there with that issue? How did you remedy it? I would be extremely excited to hear of all the solutions out there.
tbnd88
