The Canuck Truck buildup!
Good suggestion.
lowenbrau said:
Ah, I had those in my hand as well but decided against it because they protrude too much from the surface. I'm going to try and make the surface as smooth as possible so that I can easily slide items on and off should I need to when the RTT is not attached.
Thanks for the tip though. I don't mind speding a bit more time and predrilling.
Cheers,
P
You should be able to go to the Auto Paint store and buy similar screws to the ones lowenbrau posted, but with a flat head... they come in a green box with white lettering... not too sure of the brand name off the top of my head.
I'll look at my box when I get home and let you know who makes them, they are metal on metal self tapping screws, with the tip of the screw base the same (like the 10mm and 12mm on the taco's)... no pre-drilling required.
Screws.
Excellent, post up a picture of the box or the brand if you can. :sombrero:
looking great P!!!
I too am getting ready to mount my RTT on my trailer.....Just got done moving into a much larger basecamp!
Can't wait to see the final setup on the RTT you got!
Can't wait to see how your platform turns out. Have you figured out how you are going to get to items in your truck bed under the tent?
Platform ideas.
I'm still deciding what to do with the platform (i.e. hinged vs. solid). I don't have my tool box yet so I'm in a holding pattern untill then.
Cheers,
P
G.E.A.R. seat cover
A little while back I picked up some cool GEAR seat covers but never got arround to taking pictures.
They fit relatively well, not perfect but they work. Many storage configurations/options. I like them.
Cheers,
P
Yaesu FT-7800R radio installation.
Communications Upgrade!
After carful consideriation and reading here on ExPo the following components were selected:
Yaesu FT-7800R & separation kit (YSK-7800)
Larsen NMO 2/70B
Since I got a clean bill of health for the frame for Toyota I decided to install my 2m radio. No sense in doing all the work if the truck was heading to the junk pile!
The previous owner had mounted a CB to the centre console and the screw holes had always annoyed me. So, I took care of that problem:
After doing some testing for a mounting location and realizing that I don't need the ash tray since I don't smoke the solution was quite evident!
Remove the ash tray and then the ash tray holder held in place by two screws.
Be careful when you remove the ash tray because there is a small light bulb attached. Mine never worked anyhow, but it just pull straight out.
Some of the parts and pieces.
To be continued...
Yaesu FT-7800R radio installation continued
I used some cardboard and made up a template for the bracket. Then I used some of the diamond plate (1/8") that was in the garage. After 10 minutes worth of cutting, drilling, deburring, bending and painting I had a cool little bracket. I also painted it, did not want to blind myself with all the shiny stuff!
Next I mounted the separation kit to the bracket using the supplied hardware.
Then I attached the bracked to the existing holes.
After a bit of time routing the wires under the centre console for a clean look this is what it looks like.
To be continued...
One thing that I did not like was how the mic wire was sticking out towards the passenger side right in the path where a knee could bump and break it so after a bit of electrical tape and plastic cable holder thing (not sure what you call them) I was able to use a mounting screw and hold the wire away. Here is a fuzzy picture showing what I did:
Next, I chose a temporary mounting location for the antenna while all the pieces for the tent mounting platform show up. I did take the time to clean and paint the shiny aluminium bed rail protectors with some DIY spray on bedliner for a clean black look as well.
One final shot from the driver's seat. I did angle the bracket towards the driver and up slightly for a better view of the radio. Turned out great.
When all this was finished, I took some time to program some local repeaters in as well as a few simplex frequencies that our club has selected for our trips. While I was playing with it, I called a friend who was on his way back from work (using the cell phone) and we chatted untill he was all the way home. Worked like a charm. We can now communicate!
Cheers :beer:,
P
Seat Covers
crolison said:
are those seat gear holders, the smittybuilt ones for wranglers?
taco looks good
Thanks! Yes they are the GEAR Seat Covers. They were made for a Jeep (not sure what model) but will fit on the Tacoma seats. Not perfect, but they work fine. Contact the good folks over at Sierra Expeditions, they can help you out.
Cheers,
P
Cheers,
P
Holly Molle! ...Does anyone get that joke? LOL. I love molle gear.
Its funny that you mounted your ft-7800 on the ash tray, I did the exact same thing on Sunday with my 7800. I'll post up mine later.
Tent Mounting platform progress!
Finally some progress!
As usual, finding quality products to support our beloved hobby in Eastern Canada prooved to be a challenge. For the last month I had been in a holding patter, waiting for the tool box to come in so I took the time to clean up a few things. I had an older molded plastic type bedliner that I had never been too fond about but it came with the rig when I purchased it so I endured. The tailgate piece really bothered me because it kept warping over time and causing a "catch spot" when trying to slide things out of the bed of the truck. I had enough and took it out. I purchased some DIY spray in/roll on type Bedliner to cover the tent platform once it was built. The product I picked up was made by Duplicolor and found it at my local Canadian Tire store. After seeing the result of the aluminium bed side rails, my wife suggested that I do the box with the stuff. So I though to myself what the heck I've got way more than I need...
They key to a durable finish with these products is all in the preparation. I did the following to get ready for the bedliner:
  • wiping excessive grease/Rust Check with rags
  • used pressure washer to remove the majority of grime and dirt
  • use spray nine to wipe up and remove most of the grease
  • let it dry overnight
  • cleaned it again using the degreaser provided with the DIY kit
  • scuffed up the paint using 3M pads and sand paper.
  • wiped everything down again using Acetone
Once the surface was properly prepped, I taped and tarped everthying then went to town on application. I'm very happy with the results. A pile of work and I can now appreciate the cost of Line-X. Pictures to follow.
The missing piece of the puzzle was the tool box. Now after exactly one month, the aftermaket dealer still did not have the nice black box available. Every week I spoke to the owner with no luck. So like everything else with our vehicles we came to a compromize and settled for a regular aluminium box not the nice black one as originally planned. In three days, I had a quality PCI Stellar box. Fear not my chromophobic friends, it will get a treatment of DIY bedliner as well! :sombrero:
The box has arrived!
Where possible I try and avoid made in China so this made my day.
The High-Lift fits nicely inside. Temporary solution as this time.
A small gap that will be closed/sealed up using some of diamond plate aluminium sheet left over pieces.
Now, when I get some time off from work I can prgress with building the platform a la Expeditions West! :sombrero:
Cheers,
P
Wolfbox
