These are 265's, right?
These are Goodyear duratrac LT235/85R16
Depends on how fussy you want to be with it but the easiest thing is to strip the fabric, then take off the foam with a wire brush then just paint it with household emulsion.
That was the radio that I had in my '01 D2. Sold it with the truck.
Run the cable through the wire loom that goes to the tail door. It's tight, but it can be done. Then run the cable through the same hole the washer fluid hose uses behind the spare carrier. Mount the antenna to the spare tire carrier.
That is the most elegant way to do it. For the love of God don't drill holes in the body work.
