Two days late.....Two dollars short
This unit should treat you well. I've used mine for a few years now and have since mounted it permanently in my ambo. Get quick connects for the water hose, beats screwing it on and off at each use...
Sent from my SGP511 using Tapatalk
Well I'm glad you like yours. Thanks for the tip on the quick connects. Are you using yours just as a shower or is yours hooked up to a sink as well?
Sent from my SM-G930T using Tapatalk
OLD ONE
NEW ONE
NEW ONE REFINISHED
Also swapped out the ugly AMBO grill for a standard grill.. Still need the piece that goes below it.
You're making progress, I never really thought about it, but I'm glad I don't have a grill like yours came with. Stock looks much better.
Thanks gents!! I have a lot of parts piling up. A lot of work to be done. I just ordered my solar panels today. The stock Ambo grill is defenitely hideous. I'm liking the standard grill a whole lot more.
So I was going to tackle the A/C install today. Unpacked the condenser first and realized I was not going to be doing the install until I get the right condenser.
So I started with an easy project
After that I installed a 12v plug
Then mounted the controller
As I was finishing up the controller fedex showed up
Ignore the cable running a cross the roof. It will be going to the junction box and down inside. Solar blvd sent me the cable with two of the female connectors instead of 1 female and 1 male so it's not in its final configuration. Got it hooked up though.
Figures the sun wasn't out. Lol
Agsisnehdjdjdvhskaksvsgsja!!!! Dang edgestar fridge is pissing me off. Works fine on AC but as soon as I plug it in to DC the compressor kicks on and then the display shows the volts drop from 12.6 to 11 and then the fridge stops. I disconnected it from the 8 Guage wire I had run and set the fridge next to the house batteries and tried it with only 8 inches of wire and it still does the same thing. I'm confused. The charge controller shows the batteries at 12.6????
Wolfbox
