Two Person Sleeping Bags
My wife and I used zipped together bags only once in 10°F weather. Each time one person moved, the cold air came in around the neck of the other.
After that we we kept them separate and snugged tightly around our own necks and heads. Much warmer and no blaming the other person for letting in the cold.
In those temps, I still think there are more fun things to do in a double sleeping bag!:wings:
back in the day, my parents did the same sort of thing with two mummy bags (zipping them together). remembering that, i picked up a pair of cat's meow bags a couple weeks ago for the same purpose.
they are very, very easy to link together, and provide plenty of room for two, as long as you are two who sleep like pretzels as opposed to sleeping apart. the bags are very comfortable and compress down slightly larger than a nalgene bottle :Wow1:.
i got the pair rather than a single two-person bag since you never know if youll be out separate or if youll always have the room or environment for a two-person setup side by side, plus both people get foot room, a kenny-style head wrap and a pillow slot. i did compare them to the large, square double sacks, and figured the pair of mummies would pack tighter and be more thermally efficient in cold weather than the doubles, and take up less square footage unpacked.
we linked the bags in moab last weekend with great results...the zipper going down the middle was actually more convenient imho than a side zip, since as the temperature changes each person can cover up as they need--she's always freezing, and i'm usually too warm. it also makes it a lot easier if one person has to get up in the night, or if one of you gets up earlier in the morning. they almost cover a queen-sized air mattress when theyre linked together...probably about the size of a "full".
the zipper down the middle on the bottom didnt present a problem, and the padded tube down the zipper on top is comfy...zipper never catches, and the zipper also never touches your skin (brrr).
it's also cheaper than buying two singles and a double :D.
since i've been moving around a bit lately ive been sleeping this way for a few days now, the bags are very, very comfortable with two people, as long as you normally sleep like pretzels. not so good for sleeping separate, then youre better off separating the bags.
-sean
Still Looking for the Perfect All-Condition Two Person Bag!
With our upcoming trip to Death Valley in January 2008 I am looking at our sleeping gear...
We currently have a Coleman 20 degree two person bag that is flannel lined, and my wife really likes it.
I like it except for it's size when packed... it is GINORMOUS!!!
It is as large as a fully loaded seabag even when I wrestle it as small as it will go (which is time consuming...) so it is taking up WAY too many cubic inches.
There has to be a 0 degree rated two person setup that is flannel lined and will pack down to an acceptable size, anyone have any ideas?
Wyoming Shooter said:
We've been using the Cabela's "Ultimate Adam and Eve Sleeping Bag": http://www.cabelas.com/cabelas/en/t...indexId=cat20144&hasJS=true&_requestid=100878. It's been great down to something around 20 degrees. Best regards, ELN.
It's huge when you pack it in the duffel though. We bought a set for X-Mass. They are light, so they might be a a good candidate for roof top transportation. They also come with two stuff sacks which gives you the option of packing them singly for more packing flexibility.
Yup. It's all relative I guess. "Back in the day", I used to hike across the Winds with a 75 lb. pound pack. Now, I can barely get "the necessities" into my Ford F250 Crew Cab. The older I get, the more comfort I want. Within reason, of course. :arabia: ELN
My wife and I use two rectangular bags that zip together, as others have mentioned. However, we bought one 20* bag and one 40* bag. That way we have a huge temperature range by selecting which one is on top.
Knock it off. You know I mean by selecting which sleeping bag is on top.
:elkgrin:
I did some backpacking in the seventies. Then I got married and had a family. We followed the path from back packing to car camping to RV camping.
We recently "downsized" from a 22' Arctic Fox travel Trailer. It was a great trailer, plenty stout for most gravel roads, comfortable down to 14°F. But we wanted more flexibility. Besides the only time we were in the trailer was to sleep. We get away to be outside, not look at it through a window.
Re-gearing is an adventure in itself. Trying to strike a good compromise between weight/bulk/comfort isn't any easier than in it was in my back packing days. But there are a ton more options nowadays.
2eleven
