UJOR Build Thread
Doug from CO just finished his DIY kit, looks nice! 6" with 37's squeezed under it.
2011 5.4 tear down! Going 4" on 33s.
Guys often say "anything but white" when they're looking for a van. This van proves that white can be awesome too! I love the way Trapper in UT setup his van with our 4" kit. Looks great.
Maybe I missed it but I'm interested in knowing the source of the gutter mount setup for the lightbar on this rig?
RV Tear down.
End of the day, drove it back out. The new wheels and tires should be finished tomorrow and we'll move to the rear lift and a bunch of goodies. T-case too.
Hey Chris, I noticed a while back you were working on u-bolt plates for use with the dynatrac pro rock front axel. Are you all set up now and producing parts to put together a DIY kit for someone using a pro rock?
Also just curious, does your springs from Atlas have an option to do partial military wrap.
We have the drawings but no plans to sell them as a kit yet. All of our springs have a partial military wrap, they have for a while.
RV Tear down.
Chris,
I understand from reading your post on FB, these tires and rims will be available for sale, but only the fronts and outside rears. My project is a 1993 E350 Wheeled Coach Ambulance that I cut in half and turned the rear into a heavy duty camper trailer, so I only need a set of duallies for the rear, and possibly a spare.
What size are the rims, and will the aluminum fronts and outside rears combine to make dualies? Or can a steel inner be run with an aluminum outer?
I replaced the OEM Ford axle with a Rockwell 10,000 lb. axle with electric brakes. It has 5/8" studs vs, the 9/16" OEM studs, however the old Ford rims still fit fine, and that's what I have on there now.
Thanks...
They're 16" aftermarket wheels, the fronts aren't made to be turned around and used for the rear. The steel inner can be run with an aluminum outer, no problem there.
OK, all I would need then are the two rear outer wheels, but I suppose he's not going to want to break up the set.
I'll keep looking and maybe I can find a set on eBay or somewhere. At some point, I may need to talk to you about some rear springs to get a little more body clearance off the ground.
Thanks Chris!
2eleven
