What i would build if $$ was no object
ujoint
Supporting Sponsor
I've actually posted this before but you want Photoshop hacks? Then here is mine. XP Camper shell on a heavily lifted F250 crew cab. I worked the base price out to be around $120,000 not too bad if money is no object. I guess I could add many more expensive components to burn a little more cash! I just liked the aggressive look of this set up, I also like the way the XP shell lowers for highway travel and I would add self recovery and extra fuel and water to the set up.
I like the way you think!! Here's my fantasy Xp that is actually under construction right now.
Carlyle
I pretty much have what I want now, except a few tweaks here and there. If money was no object, I would quit work tomorrow and use it 100% of the time the way it was designed to be used.
LIVEanimals
I would take my Sub wedge a 12V mated to a NV4500/205 setup, with the addition of a 60/14bff combo and a 6" lift 63" springs in the rear 56" springs in the front, rolling on 37/12.5/17s with some sort of cool expensive wheels :). Custom bumpers front and rear with Warn 12000 in them, and I saved the best two things for last I would add some sweet cab clearance lights and a cobra 29 CB.
Saiyan66
^ Sounds like a good idea, and I am pretty sure there is a truck on here that fits that description to a "T". Try searching for 12v Suburban and you should be able to find it. It is awesome.
oskarf150
