ReluctantTraveler
For my build, I'd been planning to use propane for the heat and hot water, but I've decided to weigh some other options.
My flatbed camper will be periodically removed from the bed, so integrating the heating system with the onboard gas supply isn't an option. Propane seemed like a natural fit because it's relatively clean burning, requires less maintenance, and is readily available in the US where I'll be doing most of my travel for the foreseeable future....
HOWEVER... as I've been sketching out my layout, it's become obvious that the only place that could accommodate storage for two propane tanks is underneath my kids' sleeping area, and that makes me pretty nervous given how explosive propane can be.
I'm not looking into gas/petrol and diesel heaters. I know it's possible to use standalone tanks for them. I'm also planning to max out my roof with solar panels and include at least 810ah of LiFePo4 batteries, so I'm entertaining electric as well.
New EarthCruiser's use diesel heaters with a standalone tank (the platform is all petrol motors now), and a Bosch electric water heater. I'd expect an electric heater to be wildly slow and inefficient, but I'm not opposed to using electric for both water and heat if I can make it work.
My concern with gas/diesel heaters is performance at higher altitudes (I live in the mountainous Northeast), as well as ongoing maintenance. I know they can get clogged up from exhaust which can create issues. This is part of why I'd turned away from them initially. I've also heard they can be loud and smelly.
I'm open to any and all opinions here.
