Rusty-Ford
i am very jealous! great work and what a great platform to start with.. i hope someday to build something similar!
Uhhh? If you wait to install the RTT until after the lift and tires, you realize that you just have to lift it further from the ground to rack.....right?
:sombrero: :costumed-smiley-007
That ARB fridge looks siiiick!
Your build is coming along beautifully and the truck looks nice. I see you are quite partial to all things ARB... Great write-up. Keep it coming... :coffeedrink:
The ARB fridge and location is very clean and your passenger can get to it from the front seat. Great idea to take out the split back seat.
Yep just run a horizontal cut on the table saw on 1"1/4' PVC and snap it over the handle....unless you're into 'tuckey tech' wrap some duck tape!:victory:Beautiful fridge install.
The way the fridge is tied down, the vibrations will cause those two turn buckles to migrate to the center, and become loose.
You could add some type of spacer (PVE tube) on the fridge handle (between the turn buckles) to maintain the spread.
You could add some type of spacer (PVC tube) on the fridge handle (between the turn buckles) to maintain the spread.
Hows does the ARB RTT mount to the roof? Do you have to remove the stock roof rails?
