Are you able to use the factory TPMS units with the Mojave teflons?
Good question. They are SUPPOSEDLY compatible. The local Les Schwab tire shop where I got the tires annd wheels told me yhey would work but that I had to go to the dealer to have them reset
So the stock tpms were mounted but I have not been to the dealer for the past 2.5 years since I got the wheels and tires. So the orange tire pressure light is still on on the dash. Oh well.
So the answer is yes they will work but you are better off having the tire and tpms units mounted at the dealer to make sure they are mounted correctly and calibrated to function correctly.
My suggestion is buy tires and wheels online and have the dealer yank tpms from stock wheels and mount in new wheels and then mount tires. May cost a little more but this is a gurantee it will work.....if you care about the tpms working. I don't have an outo traction system so if it does not work it does not affect my driveline...
just an annoying orange light. With the 33s you can tell quickly if you have a low tire plus I air down off road and darn ligjt would flash anyway.
