PFRAN's UZJ100 (2002 Land Cruiser 100 Series)
smittycrusher
Great write up/ build Paul. Let's get together soon and kick some more tires. I see that you, Nick and Steve have abandoned me for a 100's only group. Don't worry, I will not go away that easily! I want to hear all about that light bar!
Smitty
2000UZJ
SE Overlanding Society
Looking good ! We need to set a date for that trip out west.... I am switching to a mud tire after our last outing..
Let me know on the dates. I will start saving my pennies and hopefully I can join you guys :)
Smitty
I should of called you, first snow I plan on going up and running a few FS roads. I'll give you a ring sometime soon
haddix
This is such a good looking LandCruiser. I have thought about ditching my double cab for a 100 series. This thread isn't helping at all.
brussum
I know this is going to sound totally superficial and I'm thankful I'm not the first person to utter these words in this thread: I like that color! Thanks for the tips on the wheels, too. Good ideas.
rtaylor
Looking great. I've got a 200 in Atlanta. I'll slowly get to your level. Yall hollar if you're doing any mild trips soon. I check ExPo, Mud, GA Cruisers a couple times a week. Looking forward to seeing these in action.
Ryan
pfran42
King 2.5 Shocks with Remote Reservoir 100 Series Land Cruiser
Thanks all!
Ryan, great meeting up with you last weekend. That is one sa-weet 200 you have gotten yourself into. You have got to let my wife drive it so that I can talk her into getting one.
As for the build, I finally got the King 2.5s with remote reservoirs installed. Carl at JustDifferentials.com is great to work with and was very responsive with the 36 emails I sent him during the night I did the install.
NOTE(s):
1. The rear shocks need to be mounted with the remote reservoirs pointing towards the center of the vehicle. It will look like they will interfere with the brake lines on the driver's side but there is ample clearance.
2. A thin and thick bushing comes mounted on every shock. Place the thicker black bushing closest to the ground as it will allow for a little more droop.
3. If you have a front aftermarket bumper with a winch plate, you will have to cut the forward (included) mounting brackets for the remote reservoirs in order not to interfere with the clearances between the frame, winch plate and bumper brackets. This leaves you with one mounting hole per bracket (as opposed to three), per side to work with. I was a little worried about the reservoir being adequately secured but after a few thorough trail rides, I think it is good to go.
4. If using the supplied reservoir mounting brackets for the fronts, it will necessary to run wheel spacers if running an over-sized tire (I run 1.25" lug-centric wheel spacers up front) . I was also advised to adjust my turn-stops but after buttoning everything up, I did not experience any rubbing.
5. The rear shock mounting points on a 100 expose the naked shock shafts to potential damage from rocks/debris kicked up by the front tires. I picked up some $7 shock boots from 4WheelParts and cut the bottoms off in order to fabricate some protection for them. Cutting the boots keeps moisture from getting trapped against the shocks while at the same time lessening the chance of pitting from trail impacts. It isn't pretty, and I have gotten an ear-full from people telling me that Fox/King/Radflo/Icons should never be humiliated in such a fashion but I'm shooting for function over looks in this particular instance.
6. Not sure what all the fuss is about with getting the old rears off. I hear it can be a bear but mine came out without much of a fight. It guess it does help to use the proper tools (ratcheting box-end wrench and rubber strap wrench) and being blessed with Greek God-like strength.
On to the pics...
Right after the unboxing
Nerding out in my driveway (because I knew my wife would start making fun of me if I brought them in and checked them out at the kitchen table). I can honestly say that this is the first time I ever spent 20 minutes groping an off-road shock while drooling all over myself.
Comparison against the Monroe Reflex that the previous owner had installed. The Monroe is the same length as OEM in case anyone is wondering.
Fronts installed. The front install was made much easier by having the front up on jack stands and using a floor jack to precisely control the height of the lower control arm.
Checking for tire rub clearance on the fronts
Rears - Note that I have the remote resevoirs pointing outboard towards the tail lights. DO NOT MOUNT THEM THIS WAY.
Protecting the rear shock shafts
pfran42
And here is the only pic I have of the rig since adding the shocks...Go Figure
...and here's a video from that day. Thanks Smittycrusher!
spressomon
Look'n good Paul! I can't remember if you're running front wheel spacers or not and maybe that is the difference for you. But keep an eye out for tire to remote can interference under stuffed, fully cranked situations (along with fully mud coated tires :))...I had to relocate mine for the same reason (285/75R18 MTR Kevlar with 10mm wheel spacers).
pfran42
Yep, I have 1.25" spacers up front. I am a little worried about rubbing when aired down, turning full lock and fully articulating the wheel at the same time. I would like to get the cans mounted to the part of the frame that the upper A-arms fit into. Your thoughts?
spressomon
I would relocate them given how close they are in your photo and eliminate the concern. I wouldn't risk tearing up a remote can and/or hose and/or downstream damage especially given the solution is relatively simple...even more simple if you have or know someone with a welder...just weld a piece of angle to the front vertical area of the upper control arm mount. And based upon my experience stuff doesn't fail near home :D
The only downside to having them in the location I have mine and recommend above: When you want to let nitrogen out/recharge you need to loosen a couple screw-type bands to get access to the schrader valve atop the remote can...not that big of a deal for me ;)
pfran42
TJM AirTec Snorkel 100 Series Land Cruiser (Install)
Look what showed up in the mail...
Nice brass nutserts
New design
Major pain-in-the-butt install ahead...
Quick test fitting
I started the install but want to wrap it up before posting any related pics/notes. I'll have a full write up tomorrow.
